does I2C functions handle errors?
alexbilo
PostPosted: Tue Jun 01, 2004 3:44 pm     Reply with quote
I'm about to implement an I2C bus between two PIC18F452. Since this communication is critical to the system, I want to be able to know if the slave ACKs the data transfers. There's no documentation on this issue in CCS compiler... I just want to know what i2c_write() will do in this situation and if I can still read the ACKSTAT bit after the call to i2c_write().
Alex
rnielsen
PostPosted: Tue Jun 01, 2004 3:53 pm     Reply with quote
If you will examine the help file it states that the i2c_write() function returns the ACK bit. 0 means ACK and 1 means NO ACK. So, if you had a statement that read:
check_ack = i2c_write(address);
or
if(!i2c_write(address))// enters 'if' statement if ACK'd
you could check to see if the device ACK'd back.
Ronald
