Project Wizard " List error out of Bounds(-1)"
Steve P
PostPosted: Fri May 28, 2004 4:27 pm     Reply with quote
I'm trying to use the ccs wizard to start a project with a 16F88, but when I go through all the options it comes up with "List index out of Bounds (-1)" I have norrowed it down to something on the Analog tab as when I go to veiw code it comes up with the same error.
Any help would be appreceated
Which Version ?
PostPosted: Fri May 28, 2004 7:40 pm     Reply with quote
Which Version ?
Haplo
PostPosted: Sat May 29, 2004 1:17 am     Reply with quote
Steve, you might be using an old version IDE.
I get the 'List Index Out Of Bounds' error is so frequently that it doesn't bother me anymore. If I remember correctly, in the older days I used to get this error in the project wizard too but in the new version I'm only getting it during the normal operation. What IDE version are you running?
A few times I thought about reporting it to CCS but I don't even know where to start...
Steve P
Version
PostPosted: Sat May 29, 2004 3:16 am     Reply with quote
I'm currently running IDE version 3.41 and PCM 3.184.
The problem iss that when I get the error the project wizard simply closes down, sort of makes it useless.
