Jim McBride
| #define and port bit value testing |
Posted: Thu May 27, 2004 4:22 pm |
I have written some code and tested it with MPLAB simulator. However I am getting unexpected results when running a circuit with the debugger. I think I am doing something grossly wrong while just trying to make my code readable. Here is the basic pertinent code snippet:
#define Trig_source PIN_D0
int internal = 1, external = 0,on = 1;
while(on)
if(input(Trig_source) == internal)//internal
run_internal();
else//external
run_external();
This always tests false no matter what is on PIN_D0.
The simulator seemed to work fine using stimulous.
A mouse over shows Trig_source to have a value of 31768, as defined is the 18F452.h file.
Any ideas? |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Thu May 27, 2004 5:11 pm |
| Hard to say...post the full code. |
Posted: Thu May 27, 2004 5:20 pm |
Ok, but be warned, not too short.
#include "C:\Documents and Settings\mcbride7\Desktop\PCS DAC simulator\pcs_code\PCS_DAS_simulator.h"
//#include "A:\pcs_code\PCS_DAS_simulator.h"
#ZERO_RAM
#define T1 PIN_B3
#define T3LED PIN_B4
#define trig_55 PIN_B5
#define cables_1_1 PIN_C0
#define cables_55 PIN_C1
#define cables__46 PIN_C2
#define cables__55 PIN_C3
#define igref_1 PIN_C4
#define igref__05 PIN_C5
#define pilc_55 PIN_C6
#define pilc__46 PIN_C7
#define Trig_mode PIN_D1
#define Man_trigger PIN_D2
#define Int_trig_select PIN_D3
#define Shot_mode_full_pilc PIN_D4
#define Shot_mode_mesm PIN_D5
#define T2LED PIN_D6
#define T1LED PIN_D7
manual = 1, automatic = 0,
mesm = 1, pilc = 0, full = 1,
on = 1, off = 0, dummyVar, delay_remainder;
int16 shot_delay, delay_loops;
#int_EXT//T1
EXT_isr()
output_high(T1LED);
output_high(T1);
output_low(T1);
delay_us(50);
output_low(T1LED);
#int_EXT1//T2
EXT1_isr()
output_c(0b01000010);
//cables +.55 on
//PILC +.55 on
output_high(T2LED);//T2LED on
output_high(trig_55);//Triggers +.55 on
delay_us(20);
output_low(trig_55);//Triggers off
delay_us(30);
output_c(0b10000100);
//cables -.46 on
//PILC -.46 on
//cables +.55 off
//PILC +.55 off
output_low(trig_55);//triggers +.55 off
output_low(T2LED);//T2LED off
delay_us(60);
output_c(0b00000000);
//cables -.46 off
//PILC -.46 off
#int_EXT2//T3
EXT2_isr()
output_b(0b00110000);
output_c(0b00010001);
//T3LED on
//cables +1.1 on
//ignd,iref +.1 on
//Triggers +.55 on
delay_us(20);
output_low(trig_55);//Triggers +.55 off
delay_us(30);
output_low(T3LED);//T3LED off
delay_us(150);
output_c(00101000);
//cables -.55 on
//ignd,iref -.05 on
//cables +1.1 off
//ignd,iref +.1 off
delay_us(400);
//cables -.55 off
//ignd,iref -.05 off
init_lamp_check()
output_high(T1LED);
output_high(T2LED);
output_high(T3LED);
delay_ms(2000);
output_low(T1LED);
output_low(T2LED);
output_low(T3LED);
delay_ms(2000);
output_high(T1LED);
output_high(T2LED);
output_high(T3LED);
delay_ms(2000);
output_low(T1LED);
output_low(T2LED);
output_low(T3LED);
pilc_shot()//T1,T2
//T1
output_high(T1);
output_low(T1);
output_high(T1LED);
delay_us(50);
output_low(T1LED);
delay_ms(50);
//T2 @ T1 + 100 ms
//cables +.55 on
//PILC +.55 on
delay_us(20);
delay_us(30);
//cables -.46 on
//PILC -.46 on
//cables +.55 off
//PILC +.55 off
delay_us(60);
//output_low(cables__46);//cables -.46 off
//output_low(pilc__46);//PILC -.46 off
mesm_shot()//T1,T3
//T1
output_high(T1);
output_low(T1);
output_high(T1LED);
delay_us(50);
output_low(T1LED);
delay_ms(350);
//T3 @ T1 + 400 ms
//T3LED on
//cables +1.1 on
//ignd,iref +.1 on
//Triggers +.55 on
delay_us(20);
delay_us(30);
delay_us(150);
output_c(00101000);
//cables -.55 on
//ignd,iref -.05 on
//cables +1.1 off
//ignd,iref +.1 off
delay_us(400);
//cables -.55 off
full_shot()//T1,T2,T3
//T1
output_high(T1);
output_low(T1);//~200 ns on time
output_high(T1LED);
delay_us(50);
output_low(T1LED);
delay_ms(50);
//T2 @ T1 + 100 ms
//cables +.55 on
//PILC +.55 on
output_high(T2LED);//LED on
delay_us(20);
delay_us(30);
//cables -.46 on
//PILC -.46 on
//cables +.55 off
//PILC +.55 off
output_low(T2LED);//LED off
delay_us(60);
delay_us(190);
//T3 @ T1 + 400 ms
//LED on
//cables +1.1 on
//ignd,iref +.1 on
//Triggers +.55 on
delay_us(20);
delay_us(30);
output_low(T3LED);//LED off
delay_us(150);
output_c(00101000);
//cables -.55 on
//ignd,iref -.05 on
//cables +1.1 off
///ignd,iref +.1 off
delay_us(400);
//cables -.55 off
run_internal()
while (input(Trig_source) == internal)//internal
if (input(Int_trig_select) == manual)//manual
if (input(Man_trigger) == on)//on
if (input(Shot_mode_mesm) == mesm)//mesm
mesm_shot();
else if(input(Shot_mode_full_pilc) == full)//full
full_shot();
else //(input(Shot_mode_full_pilc) == pilc)//pilc
pilc_shot();
while (input(Int_trig_select) == automatic)//automatic
set_adc_channel(0);
delay_us(10);
shot_delay = 2000 + (63 * read_adc());//shot_delay;// = 2,000 - 10,001,adc=0-127
delay_loops = shot_delay / 255;
shot_delay = shot_delay % 255;
delay_remainder = shot_delay;
while (delay_loops)
delay_ms(255);//.5Hz - .1Hz, 2000 - 10,001 us
--delay_loops;
delay_ms(delay_remainder);
mesm_shot();
full_shot();
pilc_shot();
run_external()
enable_interrupts(global);
while (input(Trig_source) == external)//external
//wait for interrupts and service
disable_interrupts(global);
setup_adc_ports(RA0_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
ext_int_edge(H_TO_L);
ext_int_edge( 1, H_TO_L);
ext_int_edge( 2, H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
//set_tris_a (value)
set_tris_b (0b11000111);
set_tris_c (0b00000000);
set_tris_d (0b00111111);
//set_tris_e (value)
//enable_interrupts(global);
delay_ms(2000);
init_lamp_check();
internal = input(Trig_source);
while(on)
run_internal();
else//external
run_external();
}//end main |
ninjanick
| Re: #define and port bit value testing |
Posted: Sat May 29, 2004 12:04 am |
| Jim McBride wrote: |
while(on)
run_internal();
else//external
run_external();
I didn't look at the entire code, but have you tried if(input(Trig_source) only? Could be a mismatch between int and the value returned from input(). Also, to save some space you can use an int1 identifier for internal, external, on since they are only 1 bit. |
Posted: Sat May 29, 2004 4:38 am |
| Jim McBride wrote: | I have written some code and tested it with MPLAB simulator. However I am getting unexpected results when running a circuit with the debugger. I think I am doing something grossly wrong while just trying to make my code readable. Here is the basic pertinent code snippet:
while(on)
run_internal();
else//external
run_external();
Any ideas? |
As a purely 'personal' comment here, you are making the code bulkier than it needs to be. You are reading a port bit, potentially converting this to an integer, and then performing a comparison. It is quicker, and probably less likely to have errors, to take advantage of the #bit format instead. Hence:
#byte PORTD=0x??? //set this to suit your processor
#bit Trig_source=PORTD.0
Then code as:
if (Trig_source) {
//Here internal
else {
//Here external
The 'if' test here, becomes a single bit_test operation on the processor (assuming fast_io is being used), and gives less likely errors, and faster code...
Jim McBride
Posted: Tue Jun 01, 2004 10:06 am |
Gentlemen,
Thank you for your replies. I do agree that the code is bulky. But it was written so that the next person should be able to read it easily and see what I was trying to do. I did try to use #bit. And it did not work for me either. The code reads right, simulates right. So the problem must be physical right? YUP. It turned out that my solderless breadboard needs its power busses jumpered half way down the board. I was plugging into the high and low buss but there was not voltage or ground present. Everything works great now. I will take note of your comments.
Thanks!! |
Posted: Tue Jun 01, 2004 10:22 am |
| Jim McBride wrote: | Gentlemen,
Thanks!! |
Glad you found the problem. However there is no reason to make it bulkier to make it plain.
#bit Trig_source_internal=PORTD.0
Then code as:
if (Trig_source_internal) {
else {
//Here external
Makes it about as plain as possible, and results in small code too...
