Thomas Hauff Guest
RS232 in to a PC from a PIC 16F876 some time i get junk |
Posted: Tue Mar 11, 2003 6:16 pm |
Hello All
I have search the board and have not found any thing on this so maybe it is a new thing (error) or just me or equipment.
I have a project that using the 16F876 that transmits a data frame on RS422 at 12500 baud.
Seeing as this is a nonstandard baud rate I build up a RS422 to RS232 converter using a 16F867 and RS422 chip and MAX232. (Code for this is below. CCS 3.147)
Now for the issue:
I’m using the RS232 utility that comes with CCS (siow.exe) to look at the incoming data from the converter.
The issues is that if I use my old IBM Thinkpad (Windows 98, 150 Pii) and siow.exe all of the data looks good no errors or what I would expect to see.
But if I use any other computer as in Acer TravelMate 739TLV (Windows XP Pro, 1Mhz Piii) or IBM Aptiva (Windows 98, 266 Pii) and siow.exe I get junk.
It is like the bits are shifted two bits.
I have tried all types of output baud rates and paritys.
I’m so confused!
Has any one run in to this?
Have you guys got any thoughts on this?
Any help on this would be gratefully appreciated.
Thank you all.
#include <16F876.h>
//#device CCSICD=TRUE, *=16
#fuses XT,NOWDT,NOPROTECT,NOLVP
//RS 232 output and input from PC
#use RS232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, parity=o, stream=RS232)
//RS422 Input
#use RS232(baud=12500 ,rcv=PIN_C1, parity=o, bits=8, enable=pin_c0, stream=RS422)
#use fast_io(A)
#define HB_Low output_low(Pin_A5) //LED on pin 7 A5 output low
#define HB_High output_high(Pin_A5) //LED on pin 7 A5 output high
#define ints_per_ms 33 //The number of times that timer0 interrupts for 330ms heartbeat
int X1 = 0, C = 0;
static short int HBLED;
static int ms_count = ints_per_ms; //Set ms count for the 330ms heartbeat
#int_timer0
void heart_timer0() //This is the interrupt handler for the heartbeat
if ( --ms_count == 0 ) {
ms_count = ints_per_ms; //Reset the Ms counter for interrupt
if (HBLED == True) { //Test if Heartbeat LED is on
HB_Low; //Turns off HeartBeat LED
HBLED = False; //Set HBLED flag to false LED off
else { //Heartbeat LED is off
HB_High; //Turns on HeartBeat LED
HBLED = True; //Set HBLED true to false LED off
main() {
set_tris_a(0x00); //Set port a all bits to outputs for LED driver
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256 ); //Setup timer0 for button debounce
set_timer0(195); //Set timer0 for 10ms interrupt 9.984e-3 error for 10ms is 16us
enable_interrupts(GLOBAL); //Initialize all interrupts
enable_interrupts(INT_Timer0); //Turns On Timer0 interrupt for Heartbeat LED
output_a(0x00);
// output_low(PIN_c0);
while (TRUE) {
C=fgetc(RS422);
fputc(C,RS232);
C=0;
}//while (TRUE) loop
}//Main Loop
___________________________
Original Post ID: 12551 |
sar
Re: RS232 in to a PC from a PIC 16F876 some time i get junk |
Posted: Tue Mar 11, 2003 10:10 pm |
<font face="Courier New" size=-1>Hello Tom
Try this utility much better than CCS(siow.exe) and it's free.
<a href="http://bray.velenje.cx/avr/terminal/" TARGET="_blank"> <a href="http://bray.velenje.cx/avr/terminal/" TARGET="_blank">http://bray.velenje.cx/avr/terminal/</a></a></font>
Original Post ID: 12554 |
sar
Posted: Tue Mar 11, 2003 10:14 pm |
Hello Tom
Try this utility, better than CCS (siow.exe).
Original Post ID: 12555 |
Thomas Hauff Guest
Posted: Wed Mar 12, 2003 7:34 am |
Thank You All
Late last night I did figure it out!
Apparently when I build up the converter board I forgot to solder in the ground wire on the PC 232 connector. Will if the RS232 signals are not referenced to ground who know what can be coming out of it.
One thing I did learn in all of this is that the baud rate that a person sets on a PC may not be the baud rate that you get.
References: Microsoft Knowledge Base Article – 99026 “INFO: Possible Serial Baud Rates on Various Machines”
All of this info is most likely old hat to all of you.
But it may help some one some day.
Thank All
Original Post ID: 12562 |
