| #asm branch instruction not supported? |
Posted: Thu May 27, 2004 3:58 am |
#ASM
rrcf TMR1H, 0 // rotate timer 1 register through carry
bc 3 // if carry then jump 3 further
movlw 0 // clear w register
movwf LATB // set port B
bra 3 // jump 3 further
movlw 16 // set bit 5 of w register
nop // nop
nop // nop
#ENDASM
When I compile, I get an error 'Expecting an identifier'. When I comment out the 'bc' and the 'bra' instruction, it works.
Is the branch not correct?
Using v3.179 |
| Re: #asm branch instruction not supported? |
Posted: Thu May 27, 2004 4:48 am |
| Anonymous wrote: | | Code: |
#ASM
nop // nop
nop // nop
#ENDASM
Using v3.179 |
Use a label.
So:
[code]
#ASM
bra past // jump past
past:
nop // nop
nop // nop
#ENDASM
[code]
Posted: Thu May 27, 2004 5:32 am |
Honestly I can't find that in the 18FXX2 datasheet...
Should execute as follows:
| Quote: | Before instruction:
PC = address (HERE)
After instruction:
If Carry: PC = address (HERE + 12)
If no Carry: PC = address (HERE + 2)
Which should mean the BC instruction needs a relative address and not a label. Still PCWH comes up with an error...  |
Posted: Thu May 27, 2004 7:07 am |
| Anonymous wrote: | Honestly I can't find that in the 18FXX2 datasheet...
PC = address (HERE)
After instruction:
Understand, that the compiler does _not_ accept standard Microchip assembler. The syntax is closer to a C/ASM hybrid. It expects to receive a 'target', and work out for itself the offset value that is needed, rather than receiving the offset directly. You have to comply with the CCS form, rather than the Microchip form. Unfortunately, CCS, document this really badly....
The BC instruction, and the BRA instruction using a label compiles fine for me.
