kory@avatar.com Guest
ICD Work for Debugging but not normal burning |
Posted: Mon May 24, 2004 5:27 pm |
My ICD works incredibly well for source level debugging. I absolutely love it. But when I try to flash the PIC with a normal program with debugging turned off, it (my application) won't run. I can flash using the ICD2 and the exact same .HEX file using MPLAB and it works right.
Any clues?
Thanks,
Kory |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Tue May 25, 2004 7:52 am |
What do you mean won't run?
Are you using PCW or the stand-alone ICD program to burn your chip? |
ICD Work for Debuging but not notmal burning |
Posted: Wed May 26, 2004 11:57 am |
By "won't run", I mean it doesn't execute my code, as far as I can tell. The PIC is executing something else, but not my code. Maybe its not executing anything -- I can't tell. It there is a way to tell, I'd like to know as I am new to the PIC chips.
I've tried programming both ways: from inside PCW or using ICD stand alone. Again, the same hex time programmed using the ICD2 & MAPLABS works.
Thanks,
Kory
[/quote] |
