interrupt problem after migration 16f877 to 18f452
Goto page 1, 2  Next
hydrogene
PostPosted: Sun May 23, 2004 11:24 am     Reply with quote
Hi!
before to read a lot on this forum, I decide to do the migration and I changed the 16f877 for a 18f452. So when I put the code inside, the interrupt on RB0 doesn't work. (my code was working on the 16f). My compiller version is 3.2 (the last one).
When I saw that, I tried to put the simplest code, flash a led with the interrupt and it was not working to!!!!!
Here is the code :
#include <18f452.h>
#include <stdlib.h>
#fuses HS, NOWDT, NOLVP, PUT, NOBROWNOUT
#use delay (clock = 20000000)
/* Pin assignation */
#bit LED = 0xF81.7
/* function header */
#INT_EXT
void test();
SET_TRIS_B(0x00);
ext_int_edge(H_TO_L);
disable_interrupts(GLOBAL);
enable_interrupts(INT_EXT);
LED = 0;
while(1){}
#INT_EXT
void test()
LED = 1;
LED = 0;
It's working well with the 16f877 and not on the 18f452.... why Crying or Very sad
Sorry for my english Smile
Thanx a lot!!!!!!!!!!!!!!!!!!!!!!!!!!!
David
future
PostPosted: Sun May 23, 2004 11:27 am     Reply with quote
Why do you have global interrupts disabled?
hydrogene
PostPosted: Sun May 23, 2004 11:32 am     Reply with quote
I saw that on the forum, so I dont know!!!
hydrogene
PostPosted: Sun May 23, 2004 11:42 am     Reply with quote
it's not working :'(
The code is stupid... why it's not simply work????
future
PostPosted: Sun May 23, 2004 11:56 am     Reply with quote
change:
to:
hydrogene
PostPosted: Sun May 23, 2004 12:01 pm     Reply with quote
WOW, it's working!!!!!! Very Happy
thanx a lot Smile,
so why I must put all interrupts enabled ???
future
PostPosted: Sun May 23, 2004 12:07 pm     Reply with quote
Global is not all interrupts, it enables interrupt generation.
if GIE=0 an interrupt will never happen.
hydrogene
PostPosted: Sun May 23, 2004 12:32 pm     Reply with quote
it's good to know Smile
But...
It's not working on my real code... (it was only a test the old one) (I cut some innutil parts Smile)
Code :
#include <18F452.h>
#DEVICE ADC=10 *=16
#include <stdlib.h>
#use RS232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
/* Functions header */
#INT_RDA
void port(); //RS232
#INT_EXT
void ch_scr(); // Refresh LCD
#INT_TIMER1
void acq(); //acquisition timer
// Configuration des ports
SET_TRIS_A(0xFF);
SET_TRIS_B(0xFF);
SET_TRIS_C(0x08);
SET_TRIS_D(0x00);
// Configurations des ports analogiques
setup_port_a(ALL_ANALOG);
setup_adc_ports(ALL_ANALOG);
//Activer l'interruption du bouton sur un front montant
ext_int_edge(0, L_TO_H);
//Initialisation du LCD
init_lcd();
//Initialisation du timer
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
//Activation des interruptions
enable_interrupts(INT_RDA);
//******** DEBUT DU CODE ****************
if(flag_acq) //Si le flag est à ON, on fait une acquisition
acquisition();
else if(flag_com) //Si le flag est à ON, on transmet les donnees
communication();
else if(flag_btn) //Si le flag est à ON, on change d'ecran du LCD
ecran_lcd();
/* Other Functions */
void communication()
if(!strcmp(string, id)) //est-ce que le data recu est km13?
creer_trame(); //on monte une trame pour envoyer les donnees
printf("%s", trame); //on envoie les donnees
SERIAL = 0; //LED de communication à off
ON = 1; //LED PowerON à ON
flag_com = 0; //fermeture du flag
//Cette fonction incremente le compteur d'ecrans et descend le flag a 0.
void ecran_lcd()
scr++; // next page
flag_btn = 0; // flag off
prints(); //Refresh screen
//Affichage des écrans sur le LCD. Incrémentation seulement du compteur.
void prints()
//Affichage des tensions
if(scr == 1)
sprintf(lcd, "Tension du 12: %2.1f", bt);
printl(lcd, 1,1);
sprintf(lcd, "Tension du 48: %2.1f", ht);
printl(lcd, 2,1);
//Affichage des courants
else if(scr == 2)
sprintf(lcd, "Courant du 12V:%2.1f", bt_courant);
printl(lcd, 1,1);
sprintf(lcd, "Courant du 48V:%2.1f", ht_courant);
printl(lcd, 2,1);
//Affichage de la température et du fonctionnement de la génératrice
else if(scr == 3)
if(gen)
strcpy(string, "en marche");
strcpy(string, "hors fonction");
sprintf(lcd, "Temperature:%2.1f", temperature);
printl(lcd, 1,1);
sprintf(lcd, "Generatrice %s", string);
printl(lcd, 2,1);
//Affichage des statistiques pour le 12V
else if(scr == 4)
sprintf(lcd, "Statistiques pour le 12V");
printl(lcd, 1,1);
sprintf(lcd, "Prct:%3.0f temps:%3.0f", prct_bt, temps_bt);
printl(lcd, 2,1);
//Affichage des statistiques pour le 48V
else if(scr == 5)
sprintf(lcd, "Statistiques pour le 48V");
printl(lcd, 1,1);
sprintf(lcd, "Prct:%3.0f temps:%3.0f", prct_ht, temps_ht);
printl(lcd, 2,1);
//Affichage complet
else if(scr == 6)
sprintf(lcd, "12:%2.0fV %2.0fA %3.0fpct T:%2.0fC", bt, bt_courant, prct_bt, temperature);
printl(lcd, 1,1);
sprintf(lcd, "48:%2.0fV %2.0fA %3.0fpct", ht, ht_courant, prct_ht);
printl(lcd, 2,1);
//Affichage complet 12V
if(scr == 7)
sprintf(lcd, "12=> %2.1fV %2.1fA", bt, bt_courant);
printl(lcd, 1,1);
sprintf(lcd, "Temps:%2.1fH Prct:%2.1f",temps_bt, prct_bt);
printl(lcd, 2,1);
//Affichage complet 48V
if(scr == 8)
sprintf(lcd, "48=> %2.1fV %2.1fA", ht, ht_courant);
printl(lcd, 1,1);
sprintf(lcd, "Temps:%2.1fH Prct:%2.1f",temps_ht, prct_ht);
printl(lcd, 2,1);
//Remsie à zéro du compteur d'écran
scr =0;
#INT_RDA
void port()
gets(string);
flag_com = 1;
//btn
#INT_EXT
void ch_scr()
flag_btn = 1;
//timer once per second
#INT_TIMER1
void acq()
flag_acq = 1;
Thanx!!!
DAvid
future
PostPosted: Sun May 23, 2004 12:52 pm     Reply with quote
SET_TRIS_B(0xFF); set all as inputs.
change to:
SET_TRIS_B(0x00);
PostPosted: Sun May 23, 2004 3:51 pm     Reply with quote
How many times per second is your Timer1 generating an interrupt? If this is more then 10 times per second, than flag_acq will always be true and your communication or lcd-routines are never called....
hydrogene
PostPosted: Sun May 23, 2004 4:29 pm     Reply with quote
Hello !!!
My button is on pin B0 (int0). So I can not put the TrisB at 00, at lease 01.
For the Timer1, I put // (comment) it and it's not working to...
I'm so disappointed :(
Tanks
David
future
PostPosted: Sun May 23, 2004 5:52 pm     Reply with quote
I think you have to start reading the datasheet.
PostPosted: Mon May 24, 2004 3:14 am     Reply with quote
Where is the other code with flag_acq?
I don't see any initializations or resetting of this variable....
PostPosted: Tue May 25, 2004 1:53 am     Reply with quote
I very doubt the statement that this works on the 16f877 with
Disable_interrupts(GLOBAL);
Question Question Sad
Take this hint serious, mr. Hydrogene!
PostPosted: Tue May 25, 2004 3:53 am     Reply with quote
Sorry Guest, this has already been solved in his later postings.
I still think his problem is with the Timer1, it looks too fast to me:
In the Timer1 handler the flag_acq will be set. This combined with the delay_ms and the repeated if..else if...else construction will make sure he will only have time to execute the acquisition() function and nothing else.
acquisition();
communication();
ecran_lcd();
Goto page 1, 2  Next
Page 1 of 2
