How to send 10 bit ADC value as 2 bytes
doug_h
PostPosted: Thu May 20, 2004 1:04 pm     Reply with quote
I'm reading the PIC ADC in 10 bit mode and storing the result in an int16 type. I need to break up the 10 bit value into two bytes so I can send them over the network. At the other end I need to combine the two bytes back into a 10bit value and store in another int16 type. Problem is I can't get this to work. I tried the make8() and it's not doing the job. Does anyone have a solution for this?
for e.g. If my ADC = 504 the highByte should be 0x01 and lowByte should be 0xF8
But using the make8() returns highByte = 0x19 and lowByte = 0xBC
What's going on?
rnielsen
PostPosted: Thu May 20, 2004 1:32 pm     Reply with quote
You should be using make16().
int16 variable;
variable = make16(high_byte, low_byte);
Try that.
Ronald
doug_h
Fixed
PostPosted: Thu May 20, 2004 1:45 pm     Reply with quote
Thx. I had a bug in my code in the calling function - all fixed now.
