Jerry Guest
pow(x,y) code replacement with qip(x,y) function |
Posted: Mon Mar 10, 2003 7:43 pm |
I found this little snipet of code in the latest Dr. Dobbs Magazine to replace the f = pow(x,y) with f = qip(x,y).
It has a limitation that y has to be a positive integer.
It appears to be more accurate that CCS's pow() function. The qip(2.5, 5) function only 5\% rom, pow(2.5, 5) function 17\% rom.
My example below with some results.
Code: | // #define PIC_16F87X
#define PIC_18FXXX
#define 98MHZCLOCK
// #define 8MHZCLOCK
#case
#IFDEF PIC_16F87X
#include <16F876.h>
#fuses hs, nowdt, noprotect, nolvp, put
// #device PIC16F876 *=16 icd=TRUE
#device adc=8
#ENDIF
#IFDEF PIC_18FXXX
#include <18F252.h>
#include "defs_18f.h"
#fuses hs, nowdt, noprotect, nolvp, put, NOOSCSEN
#device PIC18F252 *=16
// #device PIC18F252 *=16 icd=TRUE
#device adc=8
#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01ff
void bootloader() {
#asm
nop
#endasm
} // Reserve space for the bootloader
#ENDIF
#include <math.h>
#ifdef 8MHZCLOCK
#use delay(clock=8000000) /////////// Check Crystal Value ////////////
#endif
#ifdef 98MHZCLOCK
#use delay(clock=9830400) /////////// Check Crystal Value ////////////
#endif
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
/* Compute pow(x,n)
For positive Int n
through repeated squaring */
float qip(float x, unsigned int n)
float h = 1.0;
while(n)
if (n & 1)
h *= x;
x *= x;
n >>= 1;
return h;
main()
unsigned int i;
// printf("\%9.2f ", pow(2.5,i));
for (i = 10; i < 33; i++)
printf("\%9.2f ", qip(2,i));
printf("\%9.2f\n", pow(2,i));
printf("\n");
printf("x , y qip(x,y) pow(x,y) Calculator\n");
for (i = 18; i < 24; i++)
printf("2.5,\%d ", i);
printf("\%9.2f ", qip(2.5,i));
printf("\%9.2f\n", pow(2.5,i));
printf("\n");
for (i = 3; i < 9; i++)
// printf("\%9.2f \%9.2f\n", qip(12.1,i), pow(12.1,i)); // This does not work ???
printf("12.1,\%d ", i);
printf("\%9.2f ", qip(12.1,i));
printf("\%9.2f\n", pow(12.1,i));
printf("\n");
for (i = 7; i < 14; i++)
printf("5.75,\%d ", i);
printf("\%9.2f ", qip(5.75,i));
printf("\%9.2f\n", pow(5.75,i));
printf("\n");
Code: | x , y qip(x,y) pow(x,y) Calculator
2.5,18 14551914.85 14551939.88 14551915.23
2.5,19 36379784.94 36379801.33 36379788.07
2.5,20 90949465.03 90949496.62 90949470.18
2.5,21 227373659.61 227373722.19 227373675.4
2.5,22 568434113.26 568435010.31 568434188.6
2.5,23 1421085424.72 1421087451.27 1421085472.0
12.1,3 1771.56 1771.56 1771.561
12.1,4 21435.88 21435.89 21435.888
12.1,5 259374.24 259374.70 259374.246
12.1,6 3138428.30 3138430.01 3138428.377
12.1,7 37974984.64 37975004.91 37974983.36
12.1,8 459497258.06 459497588.87 459497298.6
5.75,7 207814.03 207814.11 207814.0532
5.75,8 1194930.68 1194930.68 1194930.806
5.75,9 6870851.39 6870858.43 6870852.133
5.75,10 39507392.94 39507421.25 39507399.76
5.75,11 227167513.96 227167899.90 227167548.6
5.75,12 1306213229.89 1306213229.89 1306213405.0
5.75,13 7510725915.43 7510743737.22 7510727077.0 |
CCS PCH C Compiler, Version 3.146, 14129
Filename: c:\program files\picc\fp-ttspi\powtest.LST
ROM used: 1512 (5\%)
Largest free fragment is 30744
RAM used: 10 (1\%) at main() level
28 (2\%) worst case
Stack: 2 locations
only this output printf("\%9.2f ", qip(2.5,i));
ROM used: 5586 (17\%)
Largest free fragment is 26670
RAM used: 11 (1\%) at main() level
63 (4\%) worst case
Stack: 3 locations
only this output printf("\%9.2f ", pow(2.5,i));
___________________________
Original Post ID: 12512 |
Jerry Guest
Re: pow(x,y) code replacement with qip(x,y) function |
Posted: Mon Mar 10, 2003 7:54 pm |
I found that it did not paste all the code.
All I can see that is missing is.
#include <math.h> required for CCS's pow(x,y) function.
This is a keeper.
:=I found this little snipet of code in the latest Dr. Dobbs Magazine to replace the f = pow(x,y) with f = qip(x,y).
:=It has a limitation that y has to be a positive integer.
:=It appears to be more accurate that CCS's pow() function. The qip(2.5, 5) function only 5\% rom, pow(2.5, 5) function 17\% rom.
:=My example below with some results.
:=// #define PIC_16F87X
:=#define PIC_18FXXX
:=#define 98MHZCLOCK
:=// #define 8MHZCLOCK
:=#case
:=#IFDEF PIC_16F87X
:= #include <16F876.h>
:= #fuses hs, nowdt, noprotect, nolvp, put
:=// #device PIC16F876 *=16 icd=TRUE
:= #device PIC16F876 *=16
:= #device adc=8
:=#ENDIF
:=#IFDEF PIC_18FXXX
:= #include <18F252.h>
:= #include "defs_18f.h"
:= #fuses hs, nowdt, noprotect, nolvp, put, NOOSCSEN
:= #device PIC18F252 *=16
:=// #device PIC18F252 *=16 icd=TRUE
:= #device adc=8
:= #build(reset=0x200)
:= #build(interrupt=0x208)
:= #org 0x0000,0x01ff
:= void bootloader() {
:= #asm
:= nop
:= #endasm
:=} // Reserve space for the bootloader
:=#ENDIF
:=#include <math.h>
:=#ifdef 8MHZCLOCK
:= #use delay(clock=8000000) /////////// Check Crystal Value ////////////
:=#endif
:=#ifdef 98MHZCLOCK
:= #use delay(clock=9830400) /////////// Check Crystal Value ////////////
:=#endif
:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=/* Compute pow(x,n)
:= For positive Int n
:= through repeated squaring */
:=float qip(float x, unsigned int n)
:= float h = 1.0;
:= while(n)
:= if (n & 1)
:= h *= x;
:= x *= x;
:= n >>= 1;
:= return h;
:=main()
:= unsigned int i;
:=// printf("\%9.2f ", pow(2.5,i));
:= for (i = 10; i < 33; i++)
:= printf("\%9.2f ", qip(2,i));
:= printf("\%9.2f\n", pow(2,i));
:= printf("\n");
:= printf("x , y qip(x,y) pow(x,y) Calculator\n");
:= for (i = 18; i < 24; i++)
:= printf("2.5,\%d ", i);
:= printf("\%9.2f ", qip(2.5,i));
:= printf("\%9.2f\n", pow(2.5,i));
:= printf("\n");
:= for (i = 3; i < 9; i++)
:=// printf("\%9.2f \%9.2f\n", qip(12.1,i), pow(12.1,i)); // This does not work ???
:= printf("12.1,\%d ", i);
:= printf("\%9.2f ", qip(12.1,i));
:= printf("\%9.2f\n", pow(12.1,i));
:= printf("\n");
:= for (i = 7; i < 14; i++)
:= printf("5.75,\%d ", i);
:= printf("\%9.2f ", qip(5.75,i));
:= printf("\%9.2f\n", pow(5.75,i));
:= printf("\n");
:= while(TRUE)
:=/* RESULTS
:=x , y qip(x,y) pow(x,y) Calculator
:=2.5,18 14551914.85 14551939.88 14551915.23
:=2.5,19 36379784.94 36379801.33 36379788.07
:=2.5,20 90949465.03 90949496.62 90949470.18
:=2.5,21 227373659.61 227373722.19 227373675.4
:=2.5,22 568434113.26 568435010.31 568434188.6
:=2.5,23 1421085424.72 1421087451.27 1421085472.0
:=12.1,3 1771.56 1771.56 1771.561
:=12.1,4 21435.88 21435.89 21435.888
:=12.1,5 259374.24 259374.70 259374.246
:=12.1,6 3138428.30 3138430.01 3138428.377
:=12.1,7 37974984.64 37975004.91 37974983.36
:=12.1,8 459497258.06 459497588.87 459497298.6
:=5.75,7 207814.03 207814.11 207814.0532
:=5.75,8 1194930.68 1194930.68 1194930.806
:=5.75,9 6870851.39 6870858.43 6870852.133
:=5.75,10 39507392.94 39507421.25 39507399.76
:=5.75,11 227167513.96 227167899.90 227167548.6
:=5.75,12 1306213229.89 1306213229.89 1306213405.0
:=5.75,13 7510725915.43 7510743737.22 7510727077.0
:=CCS PCH C Compiler, Version 3.146, 14129
:=Filename: c:\program files\picc\fp-ttspi\powtest.LST
:= ROM used: 1512 (5\%)
:= Largest free fragment is 30744
:= RAM used: 10 (1\%) at main() level
:= 28 (2\%) worst case
:= Stack: 2 locations
:=only this output printf("\%9.2f ", qip(2.5,i));
:= ROM used: 5586 (17\%)
:= Largest free fragment is 26670
:= RAM used: 11 (1\%) at main() level
:= 63 (4\%) worst case
:= Stack: 3 locations
:=only this output printf("\%9.2f ", pow(2.5,i));
Original Post ID: 12513 |
