I have an application which needs to read an RDID tag (13.56MHz). I have the microchip supplied assembly source code, but I need to do other work on the ID once read in. Does anyone have some source code, which either replaces the assembly code all together, or incorporates the assembly, leaving the RFID in an array for easy access.
Thanks in advance.
Kasper
___________________________
Original Post ID: 1250
vistor Guest
rfdi 13.56
Posted: Wed Sep 13, 2006 7:54 pm
hi, i work in project rfid 13.56 mhz and like to change experience
