Ian McCrum
Joined: 26 Oct 2003 Posts: 14 Location: Northern Ireland
#org >64K |
Posted: Fri May 14, 2004 7:05 am |
Hi, I am currently working with a 18C801, this has no internal ROM and allows up to 2MBytes of external memory. Curent wirewrap board has 128k of flash and 128k of RAM.
I want to download executable code into the RAM, which starts at 0x20000 and then provide the user with a 'G' command to start executing it
(just the liike the good old days of mikbug and beyond...)
I have the bootloader/monitor code written and mainly working, just about ('G' is tricky...)
I need to generate code that starts at 128k and not 0x0000
I belive the statements below should do this, but they don't ( I dissassembled the code)
#build (RESET=0x20000)
#org 0x20000,0x2FFFF default
// syntax above is approximate, I am away from my own Pc at present)
The #org's produce assembler with the address clipped to the bottom 64k.
How do I set the #ORG to a value >64k ?
TIA
Ian _________________ Ian McCrum, email address held at
www.eej.ulst.ac.uk/~ian |
jaremek16 Guest
Posted: Fri May 14, 2004 7:42 am |
At first address of #build must be out of range #ORG, try:
Code: | #build (RESET=0x20000)
#org 0x2001A,0x2FFFF {} |
Second send me your file *.sta, maybe I will be able to help you.
Of course project must be compiled first.
Best regards
Jarek Gawin
jarek@eltek.com.pl |
Ian McCrum
Posted: Fri May 14, 2004 3:12 pm |
Thanks Jarek, I have also emailed you, your advice above works great, provided the addresses are less than 64k, here is code that breaks
___
// Bug/Feature in #ORG ... it is restricted to 64K
// Compiled with Version 3.120 (PCH)
// But the 18C801 can have 2 MByte of program space
// Ian McCrum , University of Ulster
#include <18C801.h>
#use rs232(baud=2400, xmit=PIN_C6,rcv=PIN_C7)
// If you swop the two lines below by adding trailing ZEROs
// you get an error : Internal Error -Contact CCS => Code 65.0.11
#build (RESET=0x2000)
#org 0x2002,0x20FF DEFAULT
//#build (RESET=0x20000)
//#org 0x20020,0x20FF0 DEFAULT
while(TRUE){
putc('+');
}//---- end while ----
}//---- end main ----
__
the working code assembles to 30 words of program and looks great, the internal error is a bit of a nusiance. Must read up to see if I can post process the intel hex file to relocate code... <sigh> _________________ Ian McCrum, email address held at
jaremek16 Guest
Posted: Mon May 17, 2004 2:22 am |
Hi Ian
I had also this problem but I solved it by reserve rest of lower memory.
(sorry for my english if you didn't understand me, I still learn)
Try this:
Code: | #include <18C801.h>
#org 0x0001A,0x0FFFF {} // leave this memory free
#org 0x10000,0x1FFFF {} // leave this memory free
while(TRUE){
putc('+');
__ |
It works on compiler 3.185
I hope that it helps you.
If you can't do it directly try to do it in other way.
By the way you can also meet other problem, how to change size of memory because standard size for compiler is only 64kB.
If you have PCW see at "tools/device editor" and choose PIC18C801, than change memory ROM from 48576 to 131072 otherwise I don't know how to solve this problem with standalone PCH compiler.
I have experiences with PIC18C601 but it is similar to 801.
I chacked my example of programme:
Code: | #include <18C601.h>
#NOLIST
#build(reset=0x20000)
#org 0x0001A,0x0FFFF {} // Reserve space for the user program
#org 0x10000,0x1FFFF {} // Reserve space for the user program
#fuses NOWDT,WDT128,HS, PUT, BW8, STVREN
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7) // ,bits=8
And as the result I can see in file prog.sta following information:
Code: | Page ROM % RAM Functions:
2 372 49 0 main
Segment Used Free
00000-00018 0 26
0001A-0FFFE 0 65510
10000-1FFFE 0 65536
20000-20002 4 0
20004-2FFFE 372 65160
30000-3FFFE 0 65536 |
Best regards |
Ian McCrum
#ORGs >64k |
Posted: Mon May 17, 2004 2:49 am |
Many many thanks for your reply, Jarek.
I have pasted your code into my compiler and I still get a CCS internal error 65:0:11, even after altering the memory size in the device editor.
I use PCH version 3.120 and note in the CCS website that it has bugs that were fixed...
// Note: http://www.ccsinfo.com/versions.shtml ... list of bugs
// 3.140 Some internal limits increased to permit very large programs
// 3.165 Some bugs with programs > 128K are now fixed
// 3.177 A problem with #org's over 0x20000 is fixed <<<<<
// 3.179 Better support for parts with external memory has been added
// 3.188 New separate bootloader examples have been added
// 3.189 Some #org issues have been addressed <<<<<<<
I have emailed CCS, maybe they will help a poor University that has bought a compiler that was sold "not fit for the purpose it was bought for"
8-(
<sigh>
The quickest fix is for me to upgrade.
Thanks again for your time.
Kindest Regards
Ian
__ ![Smile](images/smiles/icon_smile.gif) _________________ Ian McCrum, email address held at
