rachel Guest
it's toooo long but how to!!! |
Posted: Thu May 13, 2004 10:48 am |
i want to pass led1, led2, led3 into function to execute it with other output(led)
this is the program:
#include <16F876.h>
/* Set configuration bits in the PIC processor */
#fuses XT, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
//crystal, no watchdog timer, no low programming, no powerup timer, noprotect=memory protection off
#device adc=10
#device *=16
#use delay (clock=4000000) /* sets appropriate compiler constants 1µsecond instruction cycle */
#use standard_io ( a )
#use standard_io ( b )
#use standard_io ( c )
#define led1 PIN_A1 //led jaune commutateur '0'
#define led2 PIN_A2 //led verte commutateur '0'
#define led3 PIN_A3 //led rouge commutateur '0'
#define led4 PIN_A5 //led jaune commutateur 'R'
#define led5 PIN_B0 //led verte commutateur 'R'
#define led6 PIN_B1 //led rouge commutateur 'R'
#define led7 PIN_B2 //led jaune commutateur '+'
#define led8 PIN_B3 //led verte commutateur '+'
#define led9 PIN_B4 //led rouge commutateur '+'
#define led10 PIN_B5 //led jaune commutateur '-'
#define led11 PIN_B6 //led verte commutateur '-'
#define led12 PIN_B7 //led rouge commutateur '-'
#define Vpp 1024 //seuil maxi de tension
#define Vppfluct 1003 //seuil autorisé de fluctuation de la tension
#define Vppmin 973 //seuil pour lequel la tension est passée du niveau haut à un niveau plus bas*****
#define Vss 0 //seuil minimal de tension
#define Vctq 921 //seuil de chute de la tension
#define tension_maxi_touche_0 34
#define tension_mini_touche_0 0
#define tension_maxi_touche_R 790
#define tension_mini_touche_R 750
#define tension_maxi_touche_plus 523
#define tension_mini_touche_plus 463
#define tension_maxi_touche_moins 287
#define tension_mini_touche_moins 245
#define txPC PIN_C6
#define rxPC PIN_C7
#use RS232(BAUD=9600,BITS=8,XMIT=PIN_C6,RCV=PIN_C7)
#bit ADFM_BIT=0x9F.7
#bit PCFG3_BIT=0X9F.3
#bit PCFG2_BIT=0X9F.2
#bit PCFG1_BIT=0X9F.1
#bit PCFG0_BIT=0X9F.0
#byte INTCON = 0x0b //registre des interruptions
#byte PIE1 = 0x8c //registre contenant les autorisations d'interruptions
#byte PIR1 = 0x0c
#byte ADCON0 = 0x1f //registre du convertisseur
#byte ADCON1 = 0x9f //rôle des pins+justification du resultat de la conversion
#byte ADRESH = 0x1e
#byte ADRESL = 0x9e
#byte port_b = 0x06
#byte port_c = 0x07
#bit GO_DONE = ADCON0.2
#bit ADON = ADCON0.0
#bit ADIE = PIE1.6
#bit ADIF = PIR1.6
#define SET_TRIS_A = 0b00001; // PORTA AN0 entrée et les autres en sortie
#define SET_TRIS_B = 0x00; // PORTB en sortie
#define TMR1IE = PIE1.0
#define TMR1IF = PIR1.0
int16 ADCvaleur;
int32 ADCvtot;
int32 Counter1;
int32 Counter2;
int32 counter3 =499;
int32 cnt;
#int_TIMER2
TIMER2_isr()
Counter1++;
Counter2--;
ADIF=0;
void InitialiseADC ()
setup_port_a( RA0_ANALOG );
setup_adc( ADC_CLOCK_DIV_8 );
set_adc_channel( 0 );
delay_us(10);
long ADCvaleur;
long ADCvtot;
OUTPUT_B(0x00);// clear all pins on port b
ADCON0=0x81; // fosc/32, RA0, a/d off, a/d operating
ADCON1=0x8E; // an0 is a/d input, rest port a digital, internal ref, right justified
INTCON=0xc0; // enable global interrupts and peripherals
InitialiseADC();
if (ADIF=1)
ADIF = 0;
ADCvaleur = 0;
ADCvtot = 0;
setup_timer_2(T2_DIV_BY_4,5,5);
ADCvaleur=read_ADC();
Counter1==0;
while (Counter1<19999)
if (ADCvaleur>Vppfluct) //if1
output_high (led1);
if (ADCvaleur=Vppfluct)
output_low(led1);
disable_interrupts (INT_TIMER2);
delay_ms(2100);
if ((ADCvaleur<=tension_maxi_touche_0) && (ADCvaleur>=tension_mini_touche_0))
output_high(led4);
delay_ms(2000);
counter1==0;
while ((counter1<=counter3) && (ADCvaleur<=tension_maxi_touche_0) && (ADCvaleur>=tension_mini_touche_0));/* increment count */
ADCvaleur = Read_ADC(); /* read the ADC */
ADCvtot = ADCvtot + ADCvaleur; /* add it to total, for later averaging */
disable_interrupts (INT_TIMER2); /* don't allow interrupts */
ADCvtot /= (long)500; /* division par 500 échantillons pour calculer la moyenne des tensions relevée */
output_high(led6);
if ((ADCvtot<=tension_maxi_touche_0) && (ADCvtot>=tension_mini_touche_0))
output_high(led7);
output_high(led3);
delay_ms(2000);
counter1==0;
setup_timer_2(T2_DIV_BY_4,10,5);
if (ADCvaleur >= ADCvtot+ADCvtot*0.1)
disable_interrupts(INT_timer2);
output_high(led8);
delay_ms(2000);
delay_ms(20);
counter2==200;
setup_timer_2(T2_DIV_BY_4,15,5);
if ((ADCvaleur>=Vppfluct) && (counter2>=0))
output_high(led2);
output_high(led3);
output_high(led3);
output_high(led3);
if ((counter1++==19999)&&(ADCvaleur>=Vppfluct))
output_high(led3);
output_low(led1);
thank you |
Humberto
Posted: Fri May 14, 2004 1:24 am |
Dear Rachel , nfs4, or whatever nickname you choose next time,
The people in this forum, and all forums in general, are willing to help you, but they are not going to do your work for you!
Just dumping a large packet of code and saying it doesn't work is very impolite. We all have limited time, so try to be as specific with your problem as possible. Describe exactly what your program is supposed to do, what is working and what is not. And as a general rule, never post more than 20 lines of code unless asked for. If your program is larger than those 20 lines, then create a new program with only the problem part in it. Yes, this is a lot of work for you but saves us a lot of time. If you want us to help you, you have to make it easy for us.
I will give you the same advice as Neutone gave you in your previous thread: Debug your code by starting with a very small program and confirm that this works. Then add more code to it and confirm it still works. Continue this process until it stops working, than you will know there was an error in the last part added.
Without knowing what your code is supposed to do, one possible bug in your code: Code: |
Are you sure you want the ';' after the while statement? |
