The Rookie Guest
Checking to see if a pin is High or Low |
Posted: Wed May 12, 2004 3:42 pm |
I would like to develop a routine that checks to see if a pin is High or Low.
If the Pin is high it will do one thing of it is low it will do another.
The Rookie |
Joyce Guest
Posted: Wed May 12, 2004 4:12 pm |
if(input(PIN_Ax)) // pin high
do high
do low
Suus
Posted: Thu May 13, 2004 1:06 am |
Can I make it shorter like:
if(PIN_Ax)
Susan |
Haplo
Posted: Thu May 13, 2004 2:24 am |
Not in that format, but you can define a 'bit' like this:
#bit RA1=0x05.1 //On PIC16F877, 0x05 is the address of PORTA.
Now you can say:
RA1=1;
or
if(RA1)
Posted: Thu May 13, 2004 2:53 am |
Please note that the for the shorter version to work you will also have to define the I/O pin as input first! While in the 'longer' version the compiler will do this for you.
So, what is 'shorter'.... ???
Both examples lead to similar assembly code, so I guess it's a matter of taste. |
Haplo
Posted: Thu May 13, 2004 3:00 am |
Actually the pin doesn't need to be configured as input. You can use this method to read/verify the state of an output pin as well. |
Suus
Posted: Thu May 13, 2004 4:20 am |
And how to check if a pin is low?
(input(!PIN_B0))
or
(!input(PIN_B0))
Susan |
Haplo
Posted: Thu May 13, 2004 4:27 am |
input() is a C function, so:
if(!input(PIN_B0))
