OJ Guest
CCS ICD doesn't work with my board |
Posted: Mon May 10, 2004 6:01 pm |
I made the first my PIC PCB board, but the CCS ICD is not working with the board. The design of how the board works with CCS ICD has been referenced as the example 20: Migrating to your hardware, it is connected:
1: MACLR, I tried with 13.3K and 50K resistors, both don't work.
2: +5V
3: GND
4: B7
5: B6
6: B3
I took a resistor measurement of the cable I have got from CCS devleopment kit (with this cable and the evboard, it works well), the cable is the connection from evboard to CCS ICD. After the resistor measurement, I realized the number 4 of the cable is not connected or there is a capacity between it. It is different from the excise textbook! why?
When I run ICD connecting with my board, it appeared: No response icd, the firmware is wrong.
Need your helps! Thanks
oj |
Woody
Joined: 11 Sep 2003 Posts: 76 Location: Warmenhuizen - NL
Posted: Tue May 11, 2004 4:41 am |
A couple of things to check:
- Is the firmware in your ICD right for your target CPU? As far as I understand the ICD-S versions need to get different FW for 16x and 18x CPU's where the IDC-U has only one FW for both.
- Double check the layout of the connector on your board. It is easy to make a mistake in the order of the wires. Connect a logic probe to the MCLR line on your PCB and use the ICD software (Advanced - Other options - PIC16 - MCLR Square Wave) to generate a slow pulse on the MCLR pin.
- The ICD cable should be connected end-to-end on every contact, also on number 4.
I myself had a problem with the RJ11 connector (the female part) on my (brand-new) ICD. Sometimes it failed, giving me a 'could not detect target chip' error. I took apart my prototype board before I found that if I wiggled the connector in the ICD it would work again. Carefully bending the the pins inside the ICD a little upwards solved that problem, but it had me baffled for a while.
Paul |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Re: CCS ICD doesn't work with my board |
Posted: Tue May 11, 2004 6:31 am |
OJ wrote: | When I run ICD connecting with my board, it appeared: No response icd, the firmware is wrong.
If this is your problem it sounds like the ICD isn't getting power from the target board. Is this an ICD-S? Is the green LED lit on the ICD? |
there is green light in CCS ICD |
Posted: Tue May 11, 2004 10:20 am |
The PIN connection should be ok, since there is green light in CCS ICD. |
Darren Rook
Posted: Tue May 11, 2004 10:27 am |
You didn't answer if this is an ICD-S or an ICD-U. |
