rs485.c help!!!
rs485.c help!!!
PostPosted: Mon May 10, 2004 5:01 am     Reply with quote
hello!!!
sorry for my english...
I have experience programming PICs but
i dont know how the rs-485 protocol works...
has somebody a simple example of use of the RS485.c library??
i need a simple example of main program...
I want to create a network with 2-10 pics to transmit sensor's data...
I need to send and to receive data from each module...
help!!
thanks...
Shocked
mvaraujo
PostPosted: Mon May 10, 2004 7:05 am     Reply with quote
Guest,
The RS485 is not a protocol but a physical layer definition. It defines how to implement a multidrop serial network. The protocol itself is the second thing to think about and there are lots of options in the market. I would suggest you Modbus RTu because your sensors could be sold commercially as Modbus compliant devices for the market.
Marcus
Neutone
PostPosted: Mon May 10, 2004 8:26 am     Reply with quote
I recomend reading up on the MAX232 first. It's a level converter between logic and RS232. Then look at the MAX485. It's a level converter between logic and RS485. This should give you a good idea of how the hardware layer can be put togather. Forget you ever saw RS485.c
You can look in my web folder for examples and specfications for MODBUS.
PostPosted: Mon May 10, 2004 10:34 am     Reply with quote
I think/hope you mean the MAX485...
