External Program Memory
.C
PostPosted: Fri May 07, 2004 2:50 am     Reply with quote
Hi
It is possible run program from external memory on Flash Device?
Pete Smith
View user's profile Send private message Visit poster's website MSN Messenger ICQ Number
Re: External Program Memory
PostPosted: Fri May 07, 2004 6:22 am     Reply with quote
.C wrote:
Hi
I suppose it would be, in principle.
If you could put some code into high ROM on your device, you could then load instructions from external storage, copy them to the ROM of your PIC, and then execute them.
You'd have to be really careful though, regarding what you paged into where etc, and it would be quite slow.
ISTR that home computers years ago (I'm talking 20 years here) used things called "Overlays" which would dynamically load code from disk, run it, and then unload it. It would give you effectively far more code space, at the expense of speed.
Pete.
ttelmah
PostPosted: Fri May 07, 2004 6:28 am     Reply with quote
.C wrote:
Hi
Not really.
Some of the larger PICs support using external memory, and with these it could be done, if you had a flash chip with the right architecture. However The key' reason it can't be done, is the Hoffman architecture of the chip. With this design, the 'data' memory, is seperate from the program memory, so you cannot 'execute' and instruction in the data memory (which is where data read from the external memory will arrive). You can though run an 'interpreter'. Here you run a program in the PIC itself, which carries out required operations, based on the value of a data byte. This is how devices like the Stamp work.
The other alternative, would be to read a block of data from the external device, and write this into the program memory (on a flash PIC), but then you run into the limited number of write cycles supported by the program memory, and the very long time involved to transfer the data.
PostPosted: Fri May 07, 2004 2:34 pm     Reply with quote
er... Harvard architecture
PostPosted: Fri May 07, 2004 2:43 pm     Reply with quote
Argh!.
I have been looking at 'art' books recently, and did a mental 'crossover', between Heinrich Hoffman, and the computer architecture name (which derives of course from the Harvard university, where the pioneering work on this was done...).
There doen't seem to be an icon for 'embarrased grin'...
I'll be calling the shared memory/data space architecture, the Von Richtofen architecture next...
jbmiller
external memory
PostPosted: Fri May 07, 2004 3:45 pm     Reply with quote
Yes, it is possible....that's the way Basic STAMPS work isn't it ???
Haplo
PostPosted: Fri May 07, 2004 6:17 pm     Reply with quote
Mr.Hamlett, poor Howard Aiken wasn't even aware of the fact that he had painted the "Christ in the Temple", up until now... Very Happy
Re: external memory
PostPosted: Sat May 08, 2004 2:35 am     Reply with quote
Not really.
The way the Stamps work, is that they are running an 'interpreter' program, that then takes the numeric values from the external EEPROM, and branches to the different routines based on the value. The PIC does not 'run' the code in the EEPROM, but changes the block of code it executes based on the values. I outlined that this was one way you could get (partially) the required effect. However you don't have access to the 'core' functions of the processor, instead you are limited to what routines the interpreter understands.
PostPosted: Sat May 08, 2004 2:36 am     Reply with quote
Very Happy
.C
Re: external memory
PostPosted: Tue May 11, 2004 8:42 am     Reply with quote
Ttelmah wrote:
Not really.
I think about BASIC STAMP is too much expensive ( about 60$ ?) for some prjs
Re: external memory
PostPosted: Tue May 11, 2004 9:10 am     Reply with quote
.C wrote:
Ttelmah wrote:
Not really.
Have a look at:
http://www.hippy.freeserve.co.uk/diystamp.htm
PostPosted: Wed May 12, 2004 6:05 am     Reply with quote
Thank
.C
PostPosted: Wed May 12, 2004 6:06 am     Reply with quote
Anonymous wrote:
Thank
Thank by .C
