Software I2C Implementation
ritchie
PostPosted: Mon May 03, 2004 4:43 pm     Reply with quote
Is it possible to have two I2C channel? One using the MSSP hardware of the PIC and the other using a software based using PortB[5,6] as the SDA and SCL pin for the I2C.
Any suggestions and comments?
Thank u.
PostPosted: Mon May 03, 2004 5:08 pm     Reply with quote
Yes, but not at the same time. The #use i2c statement would need to be changed for each case:
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
// do hardware i2c
#use i2c(master,sda=PIN_B5,scl=PIN_B6)
// do software i2c
rnielsen
PostPosted: Tue May 04, 2004 9:00 am     Reply with quote
I've used a 16F87 to be a Slave (using the hardware I2C) while acting as a Master (using bit-banging) to a sensor. It would use software routines to communicate to the sensor and then send that data to a master that was also talking to several other PIC's doing the same thing.
Ronald
PostPosted: Tue May 04, 2004 4:56 pm     Reply with quote
Ronald
can u share few snippets on this scheme...
rnielsen
PostPosted: Wed May 05, 2004 9:15 am     Reply with quote
Here's a little bit for you. This is the Slave code that is talking to a SHT11 or SHT15 RH/Temperature sensor.
#include <16F87.h>
#use i2c(Slave,fast,sda=PIN_B1,scl=PIN_B4,restart_wdt,address=0x90)
#define XSDA PIN_A2 // sensor I2C data line
#define XSCL PIN_A3 // sensor I2C clock line
#int_SSP   // I2C interrupt service routine
SSP_isr()
int8 data;
static int8 state = 0;
   if(SSPOV)// Make sure the buffer has not overflowed
      data= SSPBUF;
      SSPOV=0;  // Clear the register
      return;
   if(STOP)
      return;
      switch(SSPSTAT & 0x2D)
         CASE 0x0C:// Master rx, slave address + 1
               CKP = 0;// hold SCL low, stretch it out
               index = 0;
               SSPBUF = stage[index];
               index++;
               CKP = 1;
         CASE 0x2C:// Master rx, data with /ack
            CKP = 0;
            index++;
            CKP = 1;
         CASE 0x28:// Master rx, data with not /ack
               sensor = 1;// enable the routine to read the sensor
               status = 1;
         default:
      }//end of switch()
   }// end of else
}// end of SSP interupt
// inserted into main()
if(sensor)// time to read the sensor
   switch(status)
      CASE 1:
         if(send_sense(0x03))// send command to read the Temperature
            status = 0;
            sensor = 0;
            if(++hey > 3)// if the sensor is not ACKing set reset bit
               puked = 1;
               hey = 0;
            status = 2;
      CASE 2:
         if(!input(XSDA))   // we need to wait until the sensor is finished
         {         // making it's measurement before we try to get
            stemp = read_sense();   // the data from it
            status = 3;
      CASE 3:
         if(!send_sense(0x05))   // this is the read command for the RH
            status = 4;
      CASE 4:
         if(!input(XSDA))   // we need to wait for the same thing as the temp
            shumid = read_sense();
            status = 5;
      CASE 5:
         if((!stemp && !shumid) || (stemp > 0x3FFF || shumid > 0xFFF)) // if the sensor has
         {                                                   // wigged out, cycle the power to it
            if(pwr++ > 10)
               puked = 1;
            cycle_power();
            TEMP = calc_temp(stemp);
            HUMI = calc_rh(shumid);
            stage[0] = (HUMI >> 8) & 0xFF;// storage of data to be sent to Master
            stage[1] = HUMI & 0xFF;
            pwr = 0;
         status = 6;
      default:
   }// end of switch()
}// end of if(sensor)
// SUBROUTINES
void rst_i2c(void)   // resets the sensor's I2C bus
int8 track;
   strt_i2c();
   for(track = 0; track < 9; track++)
      output_high(XSCL);
      delay_cycles(2);
      output_low(XSCL);
      delay_cycles(2);
   busy = 0;
}// end of rst_i2c()
void strt_i2c(void)       // I2C start signal for the sensor.  the sensor needs a slightly
{                                    // different start signal than the standard I2C protocol
   output_high(XSCL);         // calls for.
   delay_cycles(1);
   output_low(XSDA);
   delay_cycles(1);
   output_low(XSCL);
   delay_cycles(3);
   output_high(XSCL);
   delay_cycles(1);
   output_high(XSDA);
   delay_cycles(1);
   output_low(XSCL);
}// end of strt_i2c()
unsigned int1 send_sense(int8 address)
unsigned int1 ack;
   strt_i2c();
   ack = write_i2c(address);
   return(ack);
unsigned int16 read_sense(void)
unsigned int8 value1, value2;
unsigned int16 clipboard;
   value1 = read_i2c(1);
   value2 = read_i2c(0);
   clipboard = make16(value1, value2); // combine the two bytes together
   return(clipboard);
unsigned int8 read_status(void)
unsigned int8 statreg;
   statreg = read_i2c(0);
   return(statreg);
// use pins A0, A6, A7 and B7 to select address
void get_add(void)   // possible combinations
{// base address is 0x90   0x90 92 94 96 98 9A 9C 9E A0 A2  BASE:1001 0000
   if(input(PIN_A0))      //     0  1  0  1  0  1  0  1  0  1
      bit_set(SLAVE_ADDR, 1);
   if(input(PIN_A7))//        0  0  1  1  0  0  1  1  0  0
      bit_set(SLAVE_ADDR, 2);
   if(input(PIN_A6))//        0  0  0  0  1  1  1  1  0  0
      bit_set(SLAVE_ADDR, 3);
   if(input(PIN_B7))//        0  0  0  0  0  0  0  0  1  1
      bit_clear(SLAVE_ADDR, 4);
      bit_set(SLAVE_ADDR, 5);
}// end of get_add()
Ronald
ritchie
PostPosted: Thu May 06, 2004 5:14 pm     Reply with quote
I modified the code from this link http://www.ccsinfo.com/wwwboard/messages/725.html for my hardware I2C application. However, in this hardware I2C I use 8 momories for my storage thus, I have no room for additional I2C chip.
But my application needs an I2C based RTC chip like the X1226 and with the dilema I don't have any room for adding the X1226 to the existing hardware I2C setup that my application have.
So, my last option is to implement a software-based I2C using PortB as my data and clock.
My question is: would it be possible to use both hadrware I2C and software I2C taking into consideration that for my hardware I2C I never use the built-in CCS I2C function instead I make my own routines base from the URL link above?
Need your comments and suggestions...
Thanx
Haplo
PostPosted: Thu May 06, 2004 5:37 pm     Reply with quote
I did that once, I used CCS' #use I2C to implement a software I2C, and I tweaked the MSSP registers manually to use the hardware I2C module at the same time.
However the second post on this page offers an easier solution.
ritchie
PostPosted: Thu May 06, 2004 6:26 pm     Reply with quote
Got ur point...
My hardware I2C setup use the FRAM chip at a clock of 1Mhz and I don't think the #use i2c by CCS support this clock speed.. maybe it operates at 400K the most.... this is the reason why I opted for a registry tweak for my hardware I2C....
For X1226 is I guess a 100K or 400K clock speed....
Anyway, thank u for the info.... I will try this method...
Haplo
PostPosted: Thu May 06, 2004 6:53 pm     Reply with quote
I may be mistaken, but according to the PIC16F87 datasheet it seems the hardware I2C module of this PIC only supports 100KHz and 400KHz speeds.
ritchie
PostPosted: Thu May 06, 2004 7:04 pm     Reply with quote
I modified the code from the link above for my PIC18F452 microcontroller... this microcontroller supports 1MHz clock for I2C...
