another question about ccs ICD
treitmey
PostPosted: Mon May 03, 2004 3:32 pm     Reply with quote
Will the CCS ICD properly show an array of structs in the “watch” window??
ie:
struct  packet{     // Header(first 5 bytes), data(up to 26 bytes), chksum
  int8 DA;       // Desgination address recieved
  int8 size;   // Number of bytes. NOT counting header and chksum
struct packet pkt[4];
will this come up as
pkt[0].DA
pkt[0]size
pkt[1].DA
pkt[1].size
I know that microchips ICD2 doesn't show this correctly.
Douglas Kennedy
PostPosted: Mon May 03, 2004 4:01 pm     Reply with quote
It will show the array of structures with the mouse over feature in the body of your code.....I'm not certain about the watch window but it has a chance of working
treitmey
PostPosted: Tue May 04, 2004 9:22 am     Reply with quote
anyone else know about the watch window
Haplo
PostPosted: Tue May 04, 2004 5:46 pm     Reply with quote
Are you using MPLAB or PCW IDE?
treitmey
PostPosted: Thu May 06, 2004 8:41 am     Reply with quote
PCWH is not compatable with the mplab icd2. Not the same protocol. So I am compileing and using mplab icd2 to download into pic.
Haplo
PostPosted: Thu May 06, 2004 8:47 am     Reply with quote
D'oh! Very Happy
Haplo
PostPosted: Thu May 06, 2004 6:13 pm     Reply with quote
I just tested this using CCS ICD and PCW IDE. When I added pkt[0] and pkt[1] to the watch window this is what it showed me:
Expression       Value
pkt[0]              (DA: 7, size: 136)
pkt[1]              (DA: 0, size: 12)
So it appears to be working fine. However when I tried to add pkt by itself, first I got an access violation error in the ccsicdwatch.dll, and after that I got the message "Error reading RAM from the Target Device" in the 'Value' column. So it seems using CCD ICD, when dealing with an array of structs you can look at each array element with no problem, but you can't watch the whole array.
