Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Encrypt data for bootloader |
Posted: Tue May 04, 2004 1:43 pm |
I have just made the bootloader ( Loader.c) work. yay. now my boss wants me to make it so that the data send to it is encrypted so that it is not possible for "the bad guys" to just take the hex file and load it in a controller and have the whole project copied.
I was thinking of xor-ing everything in the file with some "secret" character, then have the microcontroller xor it back to normal after reception.. has anyone tried this.. any issues to watch for... any problems?.. any better ways to encrypt the data?
Thanks in Advance
Kasper[/code] |
Haplo
Posted: Tue May 04, 2004 6:03 pm |
As long as you XOR each byte of the data back to normal right after receiving it (before putting in the buffer), it should be fine. That section of Loader.C will look something like this:
do
temp=getc() ;
temp^=0x55; //Or any arbitrary number
buffer[buffidx] = temp;
while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
On the PC side, have you written your own uploader or are you using CCS' "Serial Port Monitor"? If you just encrypt the HEX file and then feed it to Serial Port Monitor it may not work because that program may be using CR/LFs to read a full line and send it to the PIC, but XORing will destroy CR/LFs. |
Guest Guest
Recursion |
Posted: Tue May 04, 2004 8:13 pm |
Use some form of recursion |
hillcraft
Joined: 22 Sep 2003 Posts: 101 Location: Cape Town (South africa)
Code protection and bootloaders |
Posted: Wed May 05, 2004 12:52 am |
As far as I am aware bootloaded pics have serious code protection issues.
It seems that the pic can have code protection on / off for the entire pic including the bootloader. This means that if you have et the code protect flag after you have loaded your code, you cannot reload the code without reloading the entire bootloader. This kinda defeats the object of using a bootloader - does it not? |
Re: Encrypt data for bootloader |
Posted: Wed May 05, 2004 2:39 am |
Kasper wrote: | I have just made the bootloader ( Loader.c) work. yay. now my boss wants me to make it so that the data send to it is encrypted so that it is not possible for "the bad guys" to just take the hex file and load it in a controller and have the whole project copied.
Thanks in Advance
Kasper[/code] |
To encrypt, requires that you 'structure' your code in a fairly particular way. You need to have the bootloader, which lives in the first area of the ROM. This has to be set to have code protection, and write protection enabled. You then encrypt your data at a level that is dependant on the protection required (you seem to be assuming that people will have access to your file - do you trust the people who will upgrade the systems or not - if you trust the 'upgraders', then encryption of the data is pointess - otherwise your 'code' can range from a simple sequential 'XOR' with a data pattern, through to multi-element polynomial encryption, but remember that the decoding algorithm needs to live in the bootblock, and hence the size will be fairly limited). Then you obviously have to have code protection enabled across the chip, but leave write protection disabled (otherwise the bootloader can't program the chip). I'd look at XORing with a byte pattern, starting at the beginning of the data and working forwards, then when the pattern expires, use the results of encryption so far, as the new pattern for the next 'block' (keep the pattern and block size small, like 8/16 bytes, to make the encoder/decoder fairly small as well). Then the decoder, needs only to know the first pattern word, and the result is much less predicatable than a single byte XOR. You could also have a small number of patterns, selected by the first character of the incoming data, to reduce the probability that somebody can 'spot' a pattern. It is also worth considering re-ordering the hex data, since otherwise the first line becomes relatively 'predictable', making is available as a 'crib' for cracking your code. Given that the Intel format, allows the lines to be in allmost any order, scrambling the lines, massively reduces this route to cracking the data (though the first few bytes on each line, still leave a hole...).
Kasper
Posted: Wed May 05, 2004 4:06 pm |
I will try and implement some simple XOR encryption tomorrow.. today was getting the windows software working.. I will put it up for download if anyone is interested.. source and all in VB.. all it does is the same as the CCS showio, if even that, but it works ![Smile](images/smiles/icon_smile.gif) |
hillcraft
Bootloader software |
Posted: Wed May 05, 2004 11:04 pm |
Hi Kasper,
Yes, please pulish the bootloader software, I would love to see how it works. If the copy protection works I would most certainly implement it in my product. |
Kasper
Posted: Thu May 06, 2004 2:28 pm |
Here is a link to my simple bootloader + source in VB6
http://www.kmpeng.com/Flasher.zip
it still has little error handeling in it, and I have not build any encryption in, but it will load hex files to your PIC just as well as the SIOW program from CCS.
it will time out if there is no response from the PIC in 2 seconds, so make sure it is in boot mode before sending stuff to it
Feel free to use this code to make a pretty interface for your end users, or use it as is.
Only thing.. if you add usefull functionality to it, please share the code
standard disclaimer.. I will not be held responsible for any damage this file will do in the wild ( none as far as I can tell) .. so if you are nervous, open up the source and compile for yourself.. VB6 SP5 |
