does the ADC can read a voltage every 100µs during 3s and give me the result? if nop what's the minimum acquisition time _________________ nfs
Re: about ADC time acquisition
Posted: Mon May 03, 2004 12:43 pm
the T_aquision depends on the used crystal.
with a 20MHz crystal u cen get ~ every 75uS(t_aq + t_channelswitch, etc ...) a new value from your adc into a 16b variable.
Haplo
Posted: Mon May 03, 2004 5:42 pm
Quoting from datasheet (PIC16F877):
To calculate the minimum acquisition time,
Equation 11-1 may be used. This equation assumes
that 1/2 LSb error is used (1024 steps for the A/D). The
1/2 LSb error is the maximum error allowed for the A/D
to meet its specified resolution.
EQUATION 11-1: ACQUISITION TIME
TACQ=Amplifier Settling Time +
Hold Capacitor Charging Time +
Temperature Coefficient
=TAMP + TC + TCOFF
=2µs + TC + [(Temperature -25°C)(0.05µs/°C)]
The A/D conversion time per bit is defined as TAD. The
A/D conversion requires a minimum 12TAD per 10-bit
conversion. For correct A/D conversions, the A/D conversion clock
(TAD) must be selected to ensure a minimum TAD time
of 1.6 µs.
After a conversion has completed, a 2.0TAD delay must complete before acquisition can begin again. During this time, the holding capacitor is not connected to the selected A/D input channel.
