exponential operation
PostPosted: Fri Apr 30, 2004 2:54 am     Reply with quote
The equation 2^(x-1) is exponential form... Is der a way that I can express this using bit shifting operators.
Or any other suggestions..
Thnx
Haplo
PostPosted: Fri Apr 30, 2004 3:04 am     Reply with quote
As long as x>1, the following should do the job:
result=2<<(x-2);
PostPosted: Fri Apr 30, 2004 3:09 am     Reply with quote
result=2<<(x-2);
Is der another way if I'm going to start my x = 1.
thnx
Haplo
PostPosted: Fri Apr 30, 2004 3:13 am     Reply with quote
Try
result=1<<(x-1);
This should work for x=1 as well.
PostPosted: Fri Apr 30, 2004 3:18 am     Reply with quote
Haplo wrote:
Try
result=1<<(x-1);
Thanx
