xav27 Guest
Porting PIC16F877 to PIC18F458 problem |
Posted: Mon Apr 26, 2004 7:43 am |
Hello everybody,
I'm trying to compile a program written for a PIC16F877 to a PIC18F458.
I only changed #include <18F458.h> and PCWH give me an error :
"Out of ROM, A segment or the program is too large" !
PCWH V3.187
here is a part of my code
#include <18F458.h>
//#include <16F877.h>
#include "register.h"
#fuses HS,NOWDT,NOPUT,NOBROWNOUT,NOPROTECT,NOWRT,NOCPD,NOLVP
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N)
#use fast_io(a)
#use fast_io(c)
#define CONST_ADD 0x3F0
#ROM CONST_ADD = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00,...}
//---------- end --------
Can someone give me help
If needed, i can give more code or information
Thanks in advance.
Xavier |
ttelmah Guest
Re: Porting PIC16F877 to PIC18F458 problem |
Posted: Mon Apr 26, 2004 7:59 am |
xav27 wrote: | Hello everybody,
PCWH V3.187
#include <18F458.h>
#use fast_io(a)
#use fast_io(c)
#ROM CONST_ADD = {
Thanks in advance.
Xavier |
One thing that might be happening, is that the interrupt handler for the 18 family is significantly larger than for the 16 chips. What is 'const_add', and why do you put it in a fixed location?. You are locating it at 3F0, but not telling the compiler to avod this area (you need to use #ORG to do this). I'd suspect the interrupt handler has grown to the point where it wants to overwrite this area, and is then clashing with this declaration.
xav27 Guest
Posted: Mon Apr 26, 2004 8:31 am |
hi ttelmah,
thanks for your help.
: What is 'const_add', and why do you put it in a fixed location?
CONST_ADD is an rom area where i place some data to be changed via a modifed loader.c version.
With a RS232 link to a PC, I can change this values sending hex file(write_eeprom_program() ) it's working fine with a PIC16F877
my loader is located at 0x1C00 to 0x1CFF
I tried to add this line just after #use fast_IO(c); :
#org 0x03F0,0x1BFF {}
but no change, still have the error when compiling.
What should I do ? |
