petfo Guest
how to comment code (the right way) |
Posted: Tue Apr 20, 2004 2:54 pm |
i know this isn't realy a CCS PCx related thread, but i would realy like to see how you guys comment your code.
how detailed etc. would you for example comment and explain the source code of ex_mouse.c ?
Code: | /////////////////////////////////////////////////////////////////////////
//// EX_MOUSE.C ////
//// An example showing how to make a serial mouse using the CCS C ////
//// compiler. Your operating system / computer has to be able ////
//// to use a Microsoft Serial mouse or a Mouse Systems serial ////
//// mouse. ////
//// Requires a special CPC cable connected to Port A. ////
//// Wiring diagram for prototype board: ////
//// 40 to 53 (Button 40 becomes left mouse button) ////
//// 41 to 54 (Button 41 becomes right mouse buttom) ////
//// 9 to 15 (Pot 9 becomes X movement) ////
//// 10 to 16 (Pot 10 becomes Y movement) ////
//// 7 to 12 (PC RxD connects to PIC C6 for Xmit of data) ////
//// 11 to 47 (PC DTR connects to PIC B0 for reset interrupt) ////
//// This example will work with the PCB, PCM and PCH compilers. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#if defined(__PCB__)
#include <16c56.h>
#device ADC=8
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=1200, xmit=PIN_A3, rcv=PIN_A2,errors) // Jumpers: 11 to 17, 12 to 18
#elif defined(__PCM__)
#include <16F877.h>
#device ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOPUT
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7,errors) // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F452.h>
#device ADC=8
#define MICROSOFT TRUE
#define MOUSE_SYSTEMS FALSE //not tested. may not be compatable with Windows
#DEFINE X_CHANNEL 0
#DEFINE Y_CHANNEL 1
struct {
short int delta;
short int left;
short int right;
short int middle;
signed int x;
signed int y;
} mouse;
void clear_all_mouse(void) {
mouse.delta=0;
mouse.x=0;
mouse.y=0;
mouse.left=0;
mouse.right=0;
mouse.middle=0;
void get_data(void) {
signed int pos;
set_adc_channel(X_CHANNEL);
delay_us(10);
pos=read_adc() & 0xF8;
mouse.x=(pos-128)/10;
set_adc_channel(Y_CHANNEL);
delay_us(10);
mouse.y=(pos-128)/10;
if ((mouse.x)||(mouse.y)) {mouse.delta=1;}
void send_data(void) {
#if MICROSOFT
putc(0xC0 | (mouse.left << 5) | (mouse.right <<4 ) | ((mouse.y >> 4) & 0x0C) | ((mouse.x >> 6) & 0x03));
putc(0x80 | mouse.x & 0x3F);
putc(0x80 | mouse.y & 0x3F);
mouse.delta=0;
mouse.x=0;
mouse.y=0;
void main(void) {
clear_all_mouse();
setup_adc_ports(RA0_RA1_RA3_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
ext_int_edge(H_TO_L);
enable_interrupts(int_ext);
enable_interrupts(global);
while (TRUE) {
get_data();
if (mouse.delta) {send_data();delay_ms(17);}
Steve H. Guest
Posted: Wed Apr 21, 2004 9:34 pm |
Commenting on comments, eh?
That's always a matter of personal taste. I personally like to write comments so I put bunches of them in. You can browse my hobby site and see some code examples at www.geocities.com/hagtronics
I would recommend that you buy and read "Code Complete" by Steve McConnell - this is the best book on coding I have ever read.
Steve H. |
rwyoung
Posted: Thu Apr 22, 2004 8:15 am |
Comment as much as the code needs and no more.
In my opinion, comments have two lifetimes. Thier first lifetime is during program creation and debug when the likelyhood of the same person who wrote the code and comments will also be reading the comments. Their second lifetime is maintenence when it is more likely that somebody other than the original programmer(s) will be reading the comments.
When I comment my code I try to keep in mind that somebody else may have to work on the code after I've been killed in a freak espresso machine accident.
As to style, "Code Complete" is a good book to read but I always get a chuckle out of the fact that it is from Microsoft Press... Also the "Pragmatic Programmer" is good. There are several other "style" books around. And I found a nice (although probably a little too anal for hobby use) code formatting guide on Jack Ganssle's web site. That one you will have to Google for but I think the web site is www.ganssle.com
One last thing about comments, I try to use complete sentances with punctuation when describing code in the header block I put before each new subroutine. But inside a function I'm generally a bit more terse when commenting on the same line as code. _________________ Rob Young
dest
Posted: Thu Apr 22, 2004 9:32 am |
Try to make your commenting efficient and to the point (don't comment for the sake of commenting). I don't like the huge comment block in ex_mouse.c because of all the time it would take to get the slashes to line up correctly. I see a lot of people try to get their comments to look good. Work on content rather than formatting.
I also recommend "Code Complete" it has some of most well rounded discussion on commenting that I have seen.
Also, always document your functions. Either in the declaration or definitions. Document the parameters and return value along with what are acceptable values for the parameters. It is also good to include the original author and creation date at the top of the file.
By using good variable and function naming (Code Complete talks about this) you can reduce the amount of documentation you will need.
I believe good, clear coding is more important than good commenting. However for embedded systems, sometimes you have to pull tricks to make your code more efficient. Anything that someone would have to think about to know what you are doing should be commented.
I was always taught to comment while you code rather than afterwards. I actually don't recommend this. Often, when first creating a file, you will have to make substantial changes and work out how it will work (even if you do good design). This will make it hard to maintain comments and code (and often make your comments out-of-date). I comment after I am fairly confident that the code won't need many modifications. If you don't put it off or rush it, your commenting end up being better. |
Posted: Thu Apr 22, 2004 11:16 am |
If you look at what Code Complete recommends and what MS
actually puts in for comments, there is quite a difference. LOL.
http://www.kuro5hin.org/story/2004/2/15/71552/7795
They say the code is dated in July, so maybe these guys were
mostly summer hires ? |
Steve H Guest
Posted: Tue Apr 27, 2004 7:39 pm |
PCM's remark is funny - there is always a THEORY and an actual PRACTICE! I think this is also where the: "Managing software people is like herding cat's" theory comes in!
RW's remarks were directly at the point. I hope no one took it that I suggested that lot's of meaningless comments are worthwhile. I try to document code so I can figure out what I was doing 6 months from now - or that someone else stands a chance of figuring out my code. In my case that takes a lot of comments!
There is nothing worse than looking at a three page function where everything is a pointer to a pointer to a pointer to a table of pointers with no comments! That's why Steve M's book is such a good read - he has "Coding Horror's" sprinkled around....
Steve H. |
