LED flasher
ritchie
LED flasher
PostPosted: Mon Apr 19, 2004 11:12 pm     Reply with quote
Anyone has a sample code snippet for a LED flasher... say it turns on for 500mS at the same time it flashes then turns-off for one sec. I plan to use a timer interrupt.
Thnx
PostPosted: Tue Apr 20, 2004 12:55 am     Reply with quote
Lazy??? How about doing some research yourself before asking a question here?
There have been numerous examples of this. Use the Search function!
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Apr 20, 2004 10:34 am     Reply with quote
Hello
#include <16f877.h>
#fuses HS,NOWDT,PUT,NOLVP
signed long int t0_conta;
#int_timer0
void trata_t0 ()
   static boolean led;
   t0_conta -= 256;
   if (t0_conta<=0)
      t0_conta += 2500;
      led = !led;
      output_bit (pin_c2,led);
main()
   t0_conta = 2500;
   setup_timer_0 ( RTCC_INTERNAL | RTCC_DIV_4 );
   enable_interrupts (global | int_timer0);
   while (true); // espera interrupção
