0x37AE halts
0x37AE halts
PostPosted: Mon Apr 19, 2004 11:26 pm     Reply with quote
Friends,
Here's a uber-weird one: whatever instruction winds up at address 0x37AE of my .lst file, and I mean ANY kind of instruction, halts the processor. Just commenting out different lines makes different instructions wind up at this location, and it's the end of the line. Even the watchdog won't reboot it!
Does anyone have any idea what's up with this? If the code download "verifies" okay... then is this some kind of new weird boundary?
I haven't investigated this very fully... but when I saw that this was what was happening, I am pretty confused... and can only think of a hardware failure or witchcraft...
Thanks,
Smile Robert
ps. PIC18F8720, CCS v3.187
PostPosted: Tue Apr 20, 2004 1:08 am     Reply with quote
I wonder if you have the ICD2 set so it only programs up to a
certain address, but your code actually extends beyond that point ?
To find this setup screen, go to the Programmer menu in MPLAB
(assuming MPLAB 6.xx ) and click on Settings. Then click on
the Program tab. See if it's set to "Manually select memories
and ranges". If so, then put it back in the mode that lets the
ICD2 select them.
If you're using ICD2 in debugger mode, then the Debugger
menu also has a similar screen.
PostPosted: Tue Apr 20, 2004 5:05 am     Reply with quote
ICD2 select them.
The ICD, needs this space.
If you read the manual (...), it says:
"A small 'debug executive' program is loaded into the high area of program memory on the target PICmicro MCU. Since the debug executive must reside in program memory, the application program must not use this reserved space. The debug executive typically needs about 0x120 words of program memory."
The space needed is more than this on chips like the 18Fxx2.
You can still use the ICD2, as a programmer (dsable debug mode in the compiler fuses), but if the debugger is enabled, this program is there, and overwritting the area will cause very odd crashes...
