in the debugger there is a watch window, which says we can watch the variables used in the program change their contents as the program runs... how do u watch the special function registers change values.. there is one tab called peripherals but that does not seem to change.. it just gives u the details of the registers.
if someone could plese help me out with this it would be wonderful
thanks and regards
vaishali
Haplo
Posted: Mon Apr 19, 2004 5:55 pm
Let's say you want to watch PIR1 on PIC16F870. You can use this definition:
#byte PIR1=0x0C //0x0C is the address of PIR1
And then add PIR1 to the watch window like any other variables.
