LVD Help
chingB
LVD Help
PostPosted: Mon Apr 19, 2004 2:39 am     Reply with quote
I'd like to have your commnets regarding the code below for a low voltage detect and the schmeatics also.
schematics:
#include <18F452.H>           // Target PIC Microcontroller IC
#fuses HS,NOPROTECT,NOWDT,NOLVP,PUT     // PIC MCU Configuration
#use delay(clock=20000000)    // 20MHz Crystal clock speed
unsigned char LVDCON;
#locate LVDCON=0x0FD2
struct {
    unsigned char LVDLN:4;
    unsigned char LVDEN:1;
    unsigned char IRVST:1;
} LVDCONbits ;
#locate LVDCONbits=0x0FD2
unsigned char PIR2;
#locate PIR2=0x0FA1
struct {
    unsigned char CCP2IF:1;
    unsigned char TMR3IF:1;
    unsigned char LVDIF :1;
    unsigned char BCLIF :1;
    unsigned char EEIF  :1;
} PIR2bits ;
#locate PIR2bits=0x0FA1
int1 glLVDdetect           = 0;
#int_lowvolt
void Low_voltageDetect_isr()  // low voltage detect interrupt routine
   glLVDdetect = 1;
   while (PIR2bits.LVDIF)     // check if LVDIF is set
      PIR2bits.LVDIF = 0;     // set LVDIF to zero
void init_chip() {   // Initialize the MCU Chip
   delay_ms(2000);
   // configure LVD interrupt before enabling
   //LVDCONbits.LVDLN = 12;     // set LVD limits to 3.8Vmin ~ 4.03Vmax
   LVDCONbits.LVDLN = 15;     // external analog input
   LVDCONbits.LVDEN =  1;     // enable/powers up the LVD circuit
   while (!LVDCONbits.IRVST); // wait for LVD circuitry to stabilized?
   PIR2bits.LVDIF = 0;        // clear LVD interrupt before enabling
   setup_adc_ports(NO_ANALOGS);
   output_low(PIN_A0);
   output_high(PIN_E0);
   enable_interrupts(int_lowvolt);  // enable LVD interrupt
   enable_interrupts(GLOBAL);       // Enable Global interrupt
main()
   init_chip();
   while (TRUE)
      if (glLVDdetect)       // check if low voltage occured
         //BattManageOFF();   // battery backup is use
         glLVDdetect = 0;   // reset lvdDetect flag
         output_low(PIN_E0);
         //i8lvdtimeout = 0;  // reset lvdtimeout
         //i1LVDtmrf = 1;     // set lvdtmrf flag
         //LCD_DISPLAY(1,2,"Low Voltage     ");
My problem I can't make the LVD work using an external trip point but if I use the code above using the built-in trip point the code works... my monitroing LED at PIN_E0 will lit.
This is only a test for my final schematics which includes a battery management circuit.
I need your help on this...
Thnx
chingB
PostPosted: Mon Apr 19, 2004 5:33 pm     Reply with quote
Anyone who can help on this...
Thnx
Haplo
PostPosted: Mon Apr 19, 2004 6:02 pm     Reply with quote
I can't see your schematics. The picture doesn't load.
PostPosted: Mon Apr 19, 2004 6:17 pm     Reply with quote
Schematics link:
http://mcu-pic.100freemb.com/circuits/LVD_Circuit.gif
Haplo
PostPosted: Mon Apr 19, 2004 6:40 pm     Reply with quote
I get this:
We have detected a hotlinking error. Hotlinking is when you link to images or NON html files on 100freemb.com from another host. Hotlinking is not allowed for our FREE Accounts. Hotlinking is allowed for our paid accounts. Your account can be upgraded in the user section when you have logged in.
chingB
PostPosted: Mon Apr 19, 2004 8:11 pm     Reply with quote
Haplo wrote:
I get this:
Here is the schemaics:
