RKnapp
If two UARTS where is second rs232_errors? |
Posted: Fri Apr 16, 2004 2:41 am |
Friends,
Code: | #use rs232(DEBUGGER,stream=DEBUG)
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,bits=8,parity=n,errors,stream=COM1)
#use rs232(baud=115200,xmit=PIN_G1,rcv=PIN_G2,bits=8,parity=n,errors,stream=COM2)
Q1: "errors" in there results in the creation of a byte called "rs232_errors". But I have two real UARTS onboard my 8720. So where is the corresponding second byte?
Q2: My current treatment of this byte is, as each byte is received: (my inline comments are inferred from the help file):
Code: | // For Rx only, RS232_ERRORS contains a near-copy of RCSTAx's err bits:
if ( rs232_errors & 0x01 ) // compiler sets this
x_ErrCodes.ISRCOM2R.ParityErrors++; // bit0: not "9th bit"
if ( rs232_errors & 0x02 )
x_ErrCodes.ISRCOM2R.OverrunErrors++; // bit 1
if ( rs232_errors & 0x04 )
x_ErrCodes.ISRCOM2R.FramingErrors++; // bit 2
// Other bits are control bits -- see .pdf pg 201/366
Q3: There is apparently some kind of benefit if "errors" is included in those #use rs232 macros. But... what is the benefit? And do I have to READ the byte in order for the magic to occur...? Or set it to zero?
Thanks for your comments,
Robert (PIC18F8720, CCS v3.187) |
Posted: Fri Apr 16, 2004 5:27 am |
RS232_ERRORS, contains the error status for the last UART read, and the 9th bit, for the next one written.
The 'magic', is simply that if this is specified, and errors do occur on the UART, the driver will automatically clear the fault. I must admit, that I prefer to read the 'real' error in the status register, and clear the fault myself, but this is down to personal preference. If 'errors' is not used, a fault occurs, and is not tested for/cleared, then the UART will effectively be 'hung'...
