int32 int8 configurable?
valemike
PostPosted: Wed Apr 14, 2004 9:41 pm     Reply with quote
I need to use int32 to do integer square roots using a function i saw in this newsgroup from a past post.
However, I don't want a 32 bit int to propagate throughout my whole program, and instead use an 8 bit int throughtout the majority of the program. Is #type configurable anywhere in the program? or is it a one time thing that i am not supposed to re use in different parts of the program.
Re: int32 int8 configurable?
PostPosted: Thu Apr 15, 2004 2:42 am     Reply with quote
Types, do not 'propogate throughout the program'.
If you declare:
int8 fred, dick;
int16 tom, harry;
harry=tom*200L;
Then the arithmetic to calculate 'harry', will be done using 16bit maths.
However if on the next line you type:
fred=dick*20;
Then the arithmetiic to calculate 'fred' will use 8bit maths.
If you then type:
fred=tom/2;
The arithmetic will use 16bit maths (since tom is a 16bit variable), and the 'result' will then be converted to 8bit. However if you use:
fred=(int8)tom/2;
Tom will be converted to 8bit, and then divided by 2, using 8bit arithmetic.
If you then use:
tom=fred*2;
The cmpiler will calculate fred*2, using 8bit arithmetic, and convert the result to 16bit. Unfortunately this brings the risk of overflow. So if instead you use:
tom=(int16)fred*2;
or
tom=fred*2L;
This forces one of the two variables used in the calculation to be a 'long' before the arithmetic starts, and forces 16bit maths to be used.
The compiler switches the arithmetic used, according to the types of the variables involved in each part of the statement. There is a 'caveat' with this, in that it is easy to miss where the compiler may use 8bit arithmetic, in a section, where you think it i using a longer form, and data loss (overflows) may result. The 'plus', is that the compiler will tend to use shorter arithmetic routines, than if it always chose the 'longest' type in an entire statement.
Use the 'cast' (bracketing a number 'type' declaration in front of a variable), to force conversion to the type that you want to be used for the arithmetic.
