Franz Guest
Real problem by uchar or int8 |
Posted: Thu Apr 08, 2004 4:32 am |
Hello my problems is : Can I do a shift 24 (>> 24) by ulong byte (int32) in a uchar.
If I write:
void tipol ( ulong misura, uchar offset )
uchar var ;
var = 0xff&(misura >> 24) ;
Can i do it in a uchar?
Is the code correct?
Thanks in advance.
Sorry for my bad english. |
Re: Real problem by uchar or int8 |
Posted: Thu Apr 08, 2004 5:04 am |
Franz wrote: | Hello my problems is : Can I do a shift 24 (>> 24) by ulong byte (int32) in a uchar.
If I write:
uchar var ;
Thanks in advance.
Yes. Since 'misura' is a 32bit value, the actual arithmetic will be done using 32bit arithmetic, and only converted at the end.
Potentially, there is a simpler instruction to get the same result:
var=make8(misura,3);
Will directly 'extract' the top byte of the 32bit value, more quickly (though the rotation should be automatically converted to a similar operation by the compilers optimisation, the 'mask' (using 0xff), will still be extra un-needed code.
Franz Guest
Posted: Wed Apr 14, 2004 9:11 am |
Thanks very much |
