how to pass 2 dimentional CONST array to a function?
Coder
PostPosted: Tue Apr 13, 2004 5:18 pm     Reply with quote
Hi..
im trying to pass a 2 dimentional CONST array to a function. i know i cant use a pointer to a CONST. what other way is there?
the array is one comprised of char . for eg.
char CONST menu_items[8][16]={"1.TX Frequency","2.Audio Subcar","3.Test Signal","4.TX on/off","5.Standby","6.Audio Meter","7.Battery Meter","8.Exit"};
im in a fix . any help would be greatly appriciated
coder
Steve H
PostPosted: Tue Apr 13, 2004 7:50 pm     Reply with quote
As I understand it a CONST was added to the C language so that a compiler would know to use a fast RAM IO location to store the value instead of inline with the code or some slow memory spot. That makes sense on BIG computers and BIG programs.
I wonder if you just make them variables with an appropriate comment that they should not change, etc, etc - what the difference would be?
The CCS compiler won't do anything differently with the values, right?
The simplest, fastest and probably safest thing to do is to make them globals and not pass them to functions - especially with small programs like would typically be found in a PIC.
I always try to think "Small C" when programming and I try to limit passing variables, etc. Let's face it the goal is to have code efficiency with a PIC. I find that most programs are well under 25 to 50 pages of source and involve only one programmer - so the simpler the better.
My thoughts on the matter - everyone elses milage may vary... ;-)
Steve H.
Haplo
PostPosted: Wed Apr 14, 2004 7:10 am     Reply with quote
Well said. Making them global is the best choice in my opinion too.
When I code for PICs, I also tend to use global variables a lot, and I usually avoid passing variables to functions if I can. This may not be a good programming practice on MSVC and all that, but my experience shows it generates the smallest and most efficient code for the PIC. Embedded coding is an art in its own way.
