Anyone wrote any code to capture a speed sensor input?
___________________________
Original Post ID: 12327
Re: CCP and speed sensor
Posted: Tue Mar 04, 2003 1:24 pm
:=Anyone wrote any code to capture a speed sensor input?
You're probably looking for examples of tachometer projects.
Here is my method of extending Timer1 to 24 bits, which
allows you to use only one CCP pre-scaler for all RPM ranges.
http://www.ccsinfo.com/forum/viewtopic.php?t=906
Edited to fix broken links.
Posted: Tue Mar 02, 2004 6:01 pm
I'm about to start.
It should be easy enough, using reed switches simply count the number of times the switch is turned on, then just do simple multiplications.
