bootloader with ccs
iyobor
bootloader with ccs
PostPosted: Sat Apr 10, 2004 10:56 am     Reply with quote
Hi Guys
Could someone clear the air on what i have to add to my c program to use a bootloader.
with picbasic i just add DEFINE LOADER_USED 1 to the begining of the program and the bootloader software knows that command.
Is the command below correct for 16f877?
#org 0x1F00, 0x1FFF void loader16F877(void) {}
What is used for 18f452 ?
iyobor
K i W i
PostPosted: Sat Apr 10, 2004 10:19 pm     Reply with quote
i always wanted to know that as well .. any help would be greatly appretiated
PostPosted: Sun Apr 11, 2004 12:00 am     Reply with quote
I'm not quite sure what you're asking.
Are you asking where to find a bootloader ?
If so, here is one.
http://www.microchipc.com/PIC18bootload/
There is Microchip's bootloader here:
http://www.microchip.com/1010/suppdoc/appnote/all/an851/index.htm
There is one here that they call CodeLoader:
http://www.thebytefactory.com/
And this one:
http://mdubuc.freeshell.org/Jolt/
Or, are you asking how to tell the CCS compiler to reserve ROM
space for the bootloader ?
If the bootloader is a small one, that takes up the first 512 bytes
of ROM in an 18F series PIC, then this link has the CCS code which
will reserve that ROM space:
http://mdubuc.freeshell.org/Jolt/#relocate
iyobor
PostPosted: Sun Apr 11, 2004 6:44 am     Reply with quote
How to Relocate User Code
CCS
Add the following directives in you .c file:
#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01ff
void bootloader() {
#asm
nop
#endasm
} // Reserve space for the bootloader
Thanks PCM
This is what i was looking for
Very much appreciated
Iyobor
