Problem with my Bootloader PIC18
faessler
PostPosted: Mon Apr 05, 2004 12:29 am     Reply with quote
i wrote an bootloader and he works fine. today I want to compile again and i get an ERROR
invalid Org range
My Code:
//#ORG 0x0006,0x001e
void IRQ1()
#asm
goto 0x2008
nop
nop
nop
nop
nop
nop
goto 0x2018
#endasm
ok -> I try the code of CCS
#int_global
void isr(void)
#asm
goto 0x2008
nop
nop
nop
nop
nop
nop
goto 0x2018
#endasm
And then I get this ERROR:
Duplicate Interrupt function
I need this function to move the IRQs to the Application.
Can anyone help me ?
regards
Oliver
Al
Re: Problem with my Bootloader PIC18
PostPosted: Mon Apr 05, 2004 5:43 am     Reply with quote
These are 2 separate problems.
invalid Org range
For the ORG error - do a search for INVALID ORG range - you will find others with the same problem. Also try to combine the above search with Author: Roger Courtney - He has some usefuls comments on it.
#int_global
void isr(void)
#asm
goto 0x2008
nop
nop
nop
nop
nop
nop
goto 0x2018
#endasm
[/quote]
For the second problem the #int_global interupt function names seems strange to me as this is a reference to all interupts. In my mind you should be waiting for a specific interrupt. For example if you are waiting for a character arriving on the RS232 line use #int_rda. Which interrupt are you waiting for?
Also Iwould rename the interupt something other than isr.
Alan Murray
