gerhard Guest
Serial port and Interrupts |
Posted: Sun Apr 04, 2004 2:34 pm |
I am using the PIC18F8720 (MPLAB6.40, CCS PCH (3.148)) and have the following problem:
I use the RS232 port to control a graphic display. When do not use interrupts everything works fine, but as soon as I enable int_rb I get garbage on the display (the whole time).
Here is the code:
#include <18F8720.h>
#fuses HS,NOWDT,noprotect,NOLVP
#use rs232(baud=9600, xmit=pin_d5,rcv=pin_d4,stream=a)
#int_rb
void rb_isr()
putc(27,a);
printf("ZL");
putc(150,a);
putc(150,a);
printf("Some text");
putc(0,a);
enable_interrupts(global);
enable_interrupts(INT_RB);
putc(27,a);
printf("DL");
putc(27,a);
printf("ZL");
putc(100,a);
putc(100,a);
printf("test");
putc(0,a);
while(true)
Any suggestions?
Gerry |
Re: Serial port and Interrupts |
Posted: Sun Apr 04, 2004 2:46 pm |
gerhard wrote: | Hello,
Here is the code:
#int_rb
void rb_isr()
putc(27,a);
printf("ZL");
putc(150,a);
putc(150,a);
putc(0,a);
putc(27,a);
printf("DL");
putc(27,a);
printf("ZL");
putc(100,a);
putc(100,a);
printf("test");
putc(0,a);
while(true)
Any suggestions?
Gerry |
You enable the port b _change_ interrupt. Then you never read port b, so this interrupt will never be reset. The interrupt routine will be continuously called...
To use the RB interrupt, _read_ port B before enabling it, and read it again inside the interrupt handler. The handler will then be called only when the port changes.
