ernest
Codes to receive RS232 data from COM 1 of PC FAILED |
Posted: Thu Apr 01, 2004 2:45 am |
I have written the following codes to check the data received by the PIC16F877A from COM 1. Basically, it echoes the data signal that it received back to the PC for us to view and verify.
However, this program does not work most of the time. On a few occasion, it echoes some irrelevant data.
Please help...
#include <16F877A.h>
#use RS232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include <input.c> //found in the CCS drivers example//
#define KEYHIT_DELAY 500 // in milliseconds ie 500 ms
char timed_getc() {
long timeout;
char retval;
timeout=0;
while(!kbhit() && (++timeout< (KEYHIT_DELAY*100)))
delay_us(10);
if(kbhit())
retval = getc();
retval = 0;
return(retval);
int status, i;
char value;
//char valid[11] = {'1','2','3','4','5','6','7','8','9','0'}; tried this but can't work
char valid;
long int temp, hum;
long int store[3];
status=1;
printf("\r\nStart typing:\r\n");
while(!kbhit());
while(status==1)
value=timed_getc();
if(value==0)
status=0;
status=1;
putc(value);
switch (value)
//Tried the following but can't work
// CASE valid:
// store[i] = buffer - 0x30 (with this you will store the integer )
// i++;
// BREAK;
CASE '0':
store[i] = value - 0x30; //Value(ASCII format) - 0x30 = Value(decimal)
i++;
BREAK;
CASE '1':
i++;
BREAK;
CASE '2':
i++;
BREAK;
CASE '3':
i++;
BREAK;
CASE '4':
i++;
BREAK;
CASE '5':
i++;
BREAK;
CASE '6':
i++;
BREAK;
CASE '7':
i++;
BREAK;
CASE '8':
i++;
BREAK;
CASE '9':
i++;
BREAK;
CASE 'C':
temp = 100*store[0] + 10*store[1] + store[2];
i = 0;
printf("%04ld Celcius",temp);
BREAK;
CASE '%':
hum = 100*store[0] + 10*store[1] + store[2];
i = 0;
printf("%04d percent",hum);
BREAK;
printf("\r\nToo slow!\r\n");
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Thu Apr 01, 2004 8:40 am |
try making it interrupt based, this way you can also make the pic do other stuff while waiting for incomming characters.
here is a code snippet, which does work for returning your characters.
It is set up to use the two hardware UARTS in the 18F6720, but on the 16F877 if you have only one, comment out the one you don't have.
As far as I am concerned, Interrupts are the way to go for RS232 communications
#include <18F6720.H> //chip we are using
#include <string.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP //define fuse settings
#use delay(clock=6000000,RESTART_WDT) //define system clock
#use rs232(baud=38400, parity=N, xmit=PIN_G1, rcv=PIN_G2, stream=PORT2, bits=8, errors) //,errors)//RS232/USB/Ethernet
#use rs232(baud=1200, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=PORT1, bits=8, errors) //,ERRORS RF Receiver
void RF_IN_Handler(void);
void rs232_handler(void);
void main(void) {
char Received;
char Received2;
int rxflag=0;
set_tris_c(0xBF); // Set pin C6 as an output
set_tris_g(0xFD); // Set pin G1 as an output
enable_interrupts(INT_RDA); // RF Receiver Interrupt
enable_interrupts(INT_RDA2);// RS232/USB/Ethernet Receiver Interrupt. Will crash the program if left floating.
enable_interrupts(GLOBAL); //enable global Interrupts
fprintf(PORT2,"\n\rSystem Initialized:\n\r"); // tells me that the port is OK
while(true){
} // end while
}// end main
#int_rda // This is the RS232 input from the rf receiver.
void RF_IN_Handler(void) {
char Received;
Received=fgetc(PORT1);
fprintf(PORT2,"%X",Received);
#int_rda2 // This is the RS232 input from the PC
void rs232_handler(void){
char Received2;
Received2=fgetc(PORT2);
fprintf(PORT2,"%c",Received2);
add your code in the interrupt handeler to check the incomming data. |
