wynnet
switch case with a range |
Posted: Wed Mar 31, 2004 4:15 pm |
How do I write a switch case with a range?
switch (number) {
case 1: tax_1() ;
case 2:
case 3:
case 4: tax_2()
case 10: /* a range of case 10 to case 99 */
case 11:
case 12:
case 99: tax_ 11percent()
default: /* example 00 or Hex Letter */
How do I do a shortcut instead of type case 10,case 11,..case 99? |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Wed Mar 31, 2004 5:00 pm |
Don't use case, use if/else. |
random_person Guest
Posted: Wed Mar 31, 2004 5:03 pm |
i'm not sure theres a way to do that with the CCSC compiler.
it looks like in your example, you are testing for ranges...so why not just use the if/else if structure to test for ranges?
if you don't like that idea, why not put in some code before the switch that sets number = to a specific integer if it is in a given range. ie...
if (number >=10 && number <100) number = 99;
switch(number) {...case 4:tax_2();break;case 99:tax_3;break;...}; |
if you can't change number, then use some temp variable. |
wynnet
Posted: Thu Apr 01, 2004 11:47 am |
thank
I use
it helps me from making human typo error. |
