Timer 1 not interrupting (PIC12F629 with 32kHz crystal)
dazlogan
PostPosted: Mon Mar 29, 2004 4:16 pm     Reply with quote
PIC = 12F629
Clock = 32kHz crystal (LP mode)
PCM = V3.153
Using MPLAB 6.4 & simulator, I cannot get timer 1 to fire.
Here's the simple code:-
#include <12F629.h>
#use delay(clock=32768)
#fuses LP,BROWNOUT,NOWDT,PUT
#int_TIMER1
TIMER1_isr() {
a++;
      setup_counters(RTCC_INTERNAL,RTCC_DIV_32);
      setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
      setup_comparator(FALSE);
      setup_vref(FALSE);
      enable_interrupts(global);
   while(1){}
Any pointers appreciated!, thanks.
Regards,
Darren
valemike
PostPosted: Mon Mar 29, 2004 4:26 pm     Reply with quote
When I use an external (not on osc1 and osc2, but rather on rc0 and rc1) 32Khz clock for Timer1, this code works:
   setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1 | T1_CLK_OUT);
But when i use an external 4MHz clock, this is what works:
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   set_timer1(0);
dazlogan
8-)
PostPosted: Tue Mar 30, 2004 1:28 am     Reply with quote
It seems to be working now, i am getting an 8 second interrupt which is correct.
Now how do I get the chip to wake up from sleep on a timer 1 interrupt?
Regards,
Darren
dazlogan
code
PostPosted: Tue Mar 30, 2004 1:36 am     Reply with quote
here's the code by the way which works:
int a;
// timer 1 interrupt, triggers every 8 seconds
#int_TIMER1
TIMER1_isr() {
   a++;
// main function
   #byte CMCON=0X19
   #byte INTCON=0X0B
   set_timer1(0);
      setup_vref(FALSE);
   CMCON=0x07;
   INTCON|=0XC0;
   while(1){
      //a++;
      //sleep();
The INTCON|=0XC0 made the difference.
But I still need to wake up from sleep.
Regards,
Darren
