Having issues while trying to use ADC
suspiciousdeveloper
PostPosted: Sun Mar 02, 2025 3:52 pm     Reply with quote
Compiler Version: V5.118
MCU: 33CH128MP202-I/SS
Hey there, while trying to use ADC the code seems to be getting stuck whenever the read_adc() function is called. Tried multiple methods but no luck, appreciate any help provided. Code is attached below:
#include <33CH128MP202.h>
#device adc=12  // Ensure 12-bit ADC resolution
#fuses NOWDT, HS  // Disable watchdog, high-speed oscillator
#use delay(crystal=10mhz, clock=180000000)
// UART1 Configuration
#pin_select U1TX = PIN_B6
#pin_select U1RX = PIN_B5
#use rs232(UART1, STREAM=UART1, baud=9600, xmit=PIN_B6, rcv=PIN_B5, ERRORS)
// ADC Configuration
#define ADC_CHANNEL 0  // **Try AN0 Instead of AN4**
#define VREF 3.3       // Reference Voltage
#define ADC_MAX 4095   // 12-bit ADC max value
#define PIN_LED PIN_B7  // **LED for debugging**
void blink_led() {
    int i;
    for (i = 0; i < 5; i++) {  // **Blink LED 5 times before ADC setup**
        output_toggle(PIN_LED);
// **Initialize ADC (With Debugging and Reset)**
void init_adc() {
    fprintf(UART1, "Initializing ADC...\r\n");
    setup_adc_ports(sAN0);         // Ensure AN0 is analog
    delay_ms(5);
    setup_adc(ADC_CLOCK_DIV_64);   // **Try a more stable clock setting**
    set_adc_channel(ADC_CHANNEL);  // Select AN0
    delay_ms(10);  // Allow ADC to stabilize
    // **Check if ADC Module is Enabled**
    if (!adc_done()) {
        fprintf(UART1, "ERROR: ADC is NOT READY! ADC module may be OFF.\r\n");
    } else {
        fprintf(UART1, "ADC Initialized Successfully.\r\n");
// **Read ADC Value with Debugging**
unsigned int16 read_adc_value() {
    unsigned int16 adc_result;
    int timeout = 5000;
    fprintf(UART1, "Starting ADC Conversion...\r\n");
    set_adc_channel(ADC_CHANNEL);  // Select correct channel
    delay_us(10);  // Small delay before conversion
    // **Use ADC_START_ONLY to Prevent Hanging**
    read_adc(ADC_START_ONLY);
    // **Timeout Protection**
    while (!adc_done() && timeout > 0) {
        delay_us(10);
        timeout--;
    if (timeout == 0) {
        fprintf(UART1, "ERROR: ADC Conversion Timed Out!\r\n");
        return 0;
    adc_result = read_adc(ADC_READ_ONLY);
    fprintf(UART1, "DEBUG: read_adc() returned: %u\r\n", adc_result);
    return adc_result;
// **Main Function**
void main() {
    unsigned int16 temp_adc;
    float voltage;
    delay_ms(100);  // Allow MCU to stabilize
    fprintf(UART1, "\r\nBOOTING SYSTEM...\r\n");
    blink_led();  // **Confirm MCU is running**
    init_adc();   // **Initialize ADC**
    while (TRUE) {
        fprintf(UART1, "Trying to read ADC...\r\n");
        temp_adc = read_adc_value();  // Get ADC reading
        voltage = (temp_adc / (float)ADC_MAX) * VREF;  // Convert ADC value to voltage
        fprintf(UART1, "ADC Read: %u | Voltage: %.2fV\r\n", temp_adc, voltage);
        delay_ms(1000);  // Read every second
PostPosted: Sun Mar 02, 2025 5:50 pm     Reply with quote
ok ,curious like my cat...FYI I've never used it but...
THAT PIC appears to be 'dual core' . If so I assume YOU have to configure what pins are ADC and where they go --> PIC #1, --> PIC #2
first though , I'd get the clock set to something reasonable, say 10MHz for test purposes AND run the '1Hz LED' program to confirm it runs....
when 'happy' have main()
do....
read ADC
send data to PC
delay 500ms
...forever
CONFIRM this works, put pot on input,vary, result should 'follow' wiper.
bottom line..go back to basics, build on code that works.
forget about 'floating point' too !!
query... is that PIC rated for 180 MHz operation at 3 volt VDD ?
PostPosted: Mon Mar 03, 2025 6:13 am     Reply with quote
He is rather pushing the core. It is rated for 180MHz, but only over a limited
supply and temperature range.
There are lots of extra complexities with these chips:
First the ADC clock source is not being specified. By default will be 'SYSTEM'.
Then, he needs to specify which ADC channel to use. On this ADC, there
are multiple SAR's feeding the single dedicated core on the master chip.
By default it will read all enabled channels, but he has none enabled.
PostPosted: Mon Mar 03, 2025 6:43 am     Reply with quote
yeesh.... sounds like a 'fun' PIC to deal with !
Kinda wondered why the 'warp speed' for the clock, especially for testing .
I KNOW board layout,wiring,etc. is critical to get more than 10 bits of good data from a 12 bit ADC.
