square roots to the nearest integer, without floating point
truevenik
PostPosted: Tue Mar 23, 2004 11:57 pm     Reply with quote
In case somebody else needs this, here's a routine that computes to the nearest integer the square-root of any unsigned 32-bit integer (eg. isqrt(10) = 3, isqrt(16) = 4 ). I needed this because I didn't have enough memory left to use floating point:
int32 isqrt(int32 x)
      int32 result = 0;
      int8 bit;
      for(bit = 15; bit != 0xFF; bit--) //while bit hasn't underflowed
          bit_set(result, bit); //set the current bit
          if(result*result > x) //if this makes the result > sqrt(x)
                bit_clear(result, bit);  //undo the bit-set
      return result;
Note 1: This can be used to compute square roots of fixed point fractions as well - lets say you represent 65.32 as 6532 in your system. You want to compute sqrt(65.32) which will be represented as 100*sqrt(65.32). To do this you compute sqrt(6532*100). The reason 100*sqrt(65.32) is equivalent to sqrt(6532*100) is: 100*sqrt(65.32)= sqrt(100*100)*sqrt(65.32) = sqrt(65.32*100*100)
Note 2: The loop finds result through guess and check (binary search) by guessing result and then checking whether (result^2 > input). If it is then the guess was too big.
Note 3: I think logarithms to the nearest integer can be computed in a similar way: log(in) = result, in = 10^result, 10^result - in = 0. find result via binary-search.
jds-pic
PostPosted: Wed Mar 24, 2004 10:58 am     Reply with quote
n.b.
there is also a solution which requires no multiplication
and therefore may consume fewer resources...
http://c.snippets.org/snip_lister.php?fname=isqrt.c
jds-pic
neat
PostPosted: Wed Mar 24, 2004 1:14 pm     Reply with quote
jds-pic wrote:
n.b.
jds-pic
Hi, can you explain the idea behind this algorithm (I don't remember learning this in grammar school Smile ?
mvaraujo
SQRT of an 32bit integer, posting code.
PostPosted: Tue Nov 30, 2004 7:56 am     Reply with quote
Hi All,
This message chain is old but I decided to post this code because it is pretty simple and can help other people that need to square a 32bit integer. It's small and fast, the best I've found in my searches until now.
long uisqrt32(int32 r)
   int32 t,b,c=0;
   for (b=0x10000000;b!=0;b>>=2) {
      t = c + b;
      c >>= 1;
      if (t <= r) {
         r -= t;
         c += b;
   return(c);
It solved speed issues on my code. In comparison to sqrt() from math.h (float) it takes 1/5 of the run time.
