How do i read/write to PIC12CE518 eeprom???
dazza
PostPosted: Sat Mar 20, 2004 4:43 am     Reply with quote
Im confused!?
How do i read/write to PIC12CE518 eeprom with CCS C?
I think I need to include a C file which doesn't exist in my drivers directory.
Thanks in advance.
Regards,
Darren
Re: How do i read/write to PIC12CE518 eeprom???
PostPosted: Sat Mar 20, 2004 5:29 am     Reply with quote
dazza wrote:
Im confused!?
Thanks in advance.
Regards,
Darren
The 12 devices handle the EEPROM differently from the other PICs. Effectively the memory, is a normal 'external' I2C EEPROM, connected to pins that don't go outside the package.
Hence the 'normal' EEPROM functions inside CCS C, cannot talk to this memory, instead you have to use the I2C functions, talking to pins GPIO6, and GPIO7.
Code to do this is in the include file 'ce51x.c', that s in the 'drivers' directory.
dazza
PostPosted: Sat Mar 20, 2004 7:17 am     Reply with quote
Ah ok, I understand, however I don't have 'ce51x.c' in my drivers directory for some reason. Confused
Can I download this from somewhere?
Regards,
Darren
dyeatman
CE51X Driver
PostPosted: Sat Mar 20, 2004 8:09 am     Reply with quote
If you dont have the driver in your examples directory you may need to upgrade your compiler.
You can get a generic version (non CCS driver) of the CE51X driver from Peter Anderson at this address:
http://www.phanderson.com/PIC/PICC/CCS_PCB/eeprom_1.html
BTW, you could have found this information by simply doing a Google search for 12CE518
dazza
ic2_defs.h
PostPosted: Tue Mar 23, 2004 4:28 pm     Reply with quote
Thanks for the above link however I'd prefer the CCS version. I don't have ic2_defs.h either !!!!!
8-(
Feeling very un-endowed in the files department here!
Any other suggestions!?
Regards,
Darren
dyeatman
Contact CCS Tech Support
PostPosted: Tue Mar 23, 2004 5:33 pm     Reply with quote
If you have a registered copy and are missing the files then use your customer number and contact CCS Tech Support. They should be able to help you get them if your version had them. If not you will need to upgrade/purchase the compiler.
Regards,
