txISR PCD
kmp84
txISR PCD
PostPosted: Wed Jan 29, 2025 8:53 am     Reply with quote
I'm trying to run "ex_stisr_pcd" but not success.
#include <33EP512MU810.h>
#device ICSP=1
#use delay(crystal=8MHz)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
#define PER_EN PIN_D5
#define PER_ON() output_high(PER_EN)
#define PER_OFF() output_low(PER_EN)
/* HW UART1 */
#pin_select U1RX=PIN_E1         // Rx Com1.
#pin_select U1TX=PIN_E0         // Tx Com1.
#use rs232(UART1,baud=9600)
#define T_BUFFER_SIZE 64
byte t_buffer[T_BUFFER_SIZE];
byte t_next_in = 0;
byte t_next_out = 0;
#int_tbe
void serial_isr() {
   if(t_next_in!=t_next_out)
      putc(t_buffer[t_next_out]);
      t_next_out=(t_next_out+1) % T_BUFFER_SIZE;
   disable_interrupts(INT_TBE);
void bputc(char c) {
   #bit U1TXIF = getenv("BIT:U1TXIF")
   short restart;
   int ni;
   restart=t_next_in==t_next_out;
   t_buffer[t_next_in]=c;
   ni=(t_next_in+1) % T_BUFFER_SIZE;
   while(ni==t_next_out);
   t_next_in=ni;
   if(restart)
      U1TXIF = 1;
void main() {
   PER_ON();
   enable_interrupts(INT_TBE);
   printf(bputc,"\r\n\Running...\r\n");
   do {
      delay_ms(2000);
      printf(bputc,"This is buffered data\r\n");
   } while (TRUE);
dsPic doesn't transmit anything!
CCS c v.5.115
Best Regards,
PostPosted: Wed Jan 29, 2025 9:09 am     Reply with quote
Hmmm..
does it transmit if you just do a normal 'print to comport' ?
do those PPS pins connect to UART or I/O pins ?
does the PC terminal program work ? loopback checked OK ?
any chance TX-->TXD, RX-->RXD ?
Always wondered if anyone did a test to see IF using a TXISR is faster and by how much ?
kmp84
PostPosted: Wed Jan 29, 2025 9:45 am     Reply with quote
temtronic wrote:
Hmmm..
Normal printf function working, no problem. Just ISR doesn't fire!
Best Regards,
PostPosted: Wed Jan 29, 2025 10:49 am     Reply with quote
Aargh.....
Does the example really have this?.
Never going to work. It'll send _one_ character.
The point is you want to only disable the interrupt if the buffer is empty.
So:
#int_tbe
void serial_isr(void)
I did point this out to CCS about three years ago.
My own buffers, which are a bit more 'universal', are:
//Buffer tests and handling
unsigned int8 btempU1RX,btempU1TX;
#define SIBUFF (64) //buffer sizes
typedef struct {
   unsigned int8 in;
   unsigned int8 out;
   unsigned int8 buff[SIBUFF];
} buffer;
buffer U1RX,U1TX; //declare these for every buffer you want.
#define incin(buff) ((buff.in==(SIBUFF-1))?0:buff.in+1)
#define incout(buff) ((buff.out==(SIBUFF-1))?0:buff.out+1)
#define isempty(buff) (buff.in==buff.out)
#define hasdata(buff) (buff.in!=buff.out)
#define isfull(buff) ((incin(buff)==buff.out)
#define tobuff(bname,c) { bname.buff[bname.in]=c;\
   bname.in=incin(bname);\
   if (bname.in==bname.out) bname.out=incout(bname);\
#define frombuff(bname) (btemp##bname=bname.buff[bname.out],\
   bname.out=incout(bname), \
   btemp##bname)
#define clrbuff(buff) buff.in=buff.out=0
#define bkbhit(BUFF) hasdata(BUFF)
#define bgetc(BUFF) frombuff(BUFF);
void U1putc(int chr)
   clear_interrupt(INT_TBE);
   tobuff(U1TX,chr);
#INT_RDA
void uart1rx(void)
   unsigned int8 temp;
   while (kbhit(U1STREAM)) {
      temp=getc();
      tobuff(U1RX, temp);
#INT_TBE
void uart1tx(void)
   unsigned int8 temp;
   temp=bgetc(U1TX);
   fputc(temp,U1STREAM);
   if (isempty(U1TX))
These allow you to just add more buffers for different serials by adding 'buffer' declarations for them, and you handle them inside the interrupts
rather like streams, just using the buffer names to say when buffer you
are talking to.
I do also though always use ERROR interrupts for the serials. The 'ERRORS'
declaration on PIC24 and up does not work. So I use an error interrupt to
handle the errors:
///UART ERROR HANDLING
#word U1STA=getenv("SFR:U1STA")
#word U2STA=getenv("SFR:U2STA")
#word U3STA=getenv("SFR:U3STA")
#word U4STA=getenv("SFR:U4STA")
#BIT UTXEN1=U1STA.10
#BIT UTXEN2=U2STA.10
#BIT UTXEN3=U3STA.10
#BIT UTXEN4=U4STA.10
#word U1MODE=getenv("SFR:U1MODE")
#word U2MODE=getenv("SFR:U2MODE")
#word U3MODE=getenv("SFR:U3MODE")
#word U4MODE=getenv("SFR:U4MODE")
#bit UARTEN1=U1MODE.15
#bit UARTEN2=U2MODE.15
#bit UARTEN3=U3MODE.15
#bit UARTEN4=U4MODE.15
#bit OERR1=U1STA.1
#bit FERR1=U1STA.2
#bit PERR1=U1STA.3
#bit OERR2=U2STA.1
#bit FERR2=U2STA.2
#bit PERR2=U2STA.3
#bit OERR3=U3STA.1
#bit FERR3=U3STA.2
#bit PERR3=U3STA.3
#bit OERR4=U4STA.1
#bit FERR4=U4STA.2
#bit PERR4=U4STA.3
#word U1RXREG=getenv("SFR:U1RXREG")
#word U2RXREG=getenv("SFR:U2RXREG")
#word U3RXREG=getenv("SFR:U3RXREG")
#word U4RXREG=getenv("SFR:U4RXREG")
#define CAT(x,y) x##y
#define CAT3(x,y,z) x##y##z
#define HASH_LIT #
#define HASH() HASH_LIT
#define EFUNCTION(x) void CAT(errorint, x) (void) { \
static int16 eword; \
if (CAT(OERR,x)) { CAT(OERR,x) = 0; return; } \
if (CAT(PERR,x)) { eword=CAT3(U,x,RXREG); } \
if (CAT(FERR,x)) { eword=CAT3(U,x,RXREG); } \
//Builds an interrupt handler to cope with UART errors.
//For parity and framing, throw the byte with the error.
#INT_UART1E LEVEL=5
EFUNCTION(1)
#INT_UART2E LEVEL=5
EFUNCTION(2)
#INT_UART3E LEVEL=5
EFUNCTION(3)
#INT_UART4E LEVEL=5
EFUNCTION(4)
//REM these out for UARTs the chip does not have
These then require the corresponding error interrupts are enabled.
These throw a byte when necessary to clear an error, and clear the
interrupt flags when this is needed.
With these buffers and error handling, I have had zero UART problems
on chips running all four UARTs at really high rates.
PostPosted: Wed Jan 29, 2025 1:01 pm     Reply with quote
Yep, the latest version compiler is still missing the else in the example...
kmp84
PostPosted: Thu Jan 30, 2025 7:00 am     Reply with quote
The problem are not only missing 'else' statement. With adding else statement still doesn't work.
PostPosted: Thu Jan 30, 2025 12:25 pm     Reply with quote
OK. Look at Jay's questions. Have you verified the chip will transmit without
using the interrupt?.
