problem with 24lc512
curt2go
PostPosted: Tue Mar 23, 2004 11:31 am     Reply with quote
The problem I am having is I asm not able to get to the top half of the eeprom. I am using the 24lc256 driver but have made the size 65536. Let me know if you can help or have a better driver that will work.. Thanx in advance.. TTY
PS I have done a search but to no avail...
Re: problem with 24lc512
PostPosted: Tue Mar 23, 2004 11:44 am     Reply with quote
I think you will find, that you need to mask the extra 'address' bit, and add it to the control words sent in the read/write operations.
You'll need to check the chips data sheet, but I think it has one bit of the control word used as the extra address.
curt2go
PostPosted: Tue Mar 23, 2004 11:53 am     Reply with quote
Got it . It was not the driver. In my reading and writing loop I was only using a long which is not a big enough numer.. TTY
