I have used these functions successfully with a PIC16F876 but when using them with a PIC18F452 the programme crashes and resets via the watchdog when I execute the longjmp.
#include <setjmp.h>
jmp_buf myenv;
// in main
do
restart_WDT();
setjmp(myenv); // Back to here
// in a function
do
key = fetch_key(); // wait for key press
if (key == 'C') // abort key ?
err = 0;
longjmp(myenv,1); // should jump to main but crashes
while (key != 'E');
Compiler version 3.184
Anyone got these to work on a PIC18Fxxx ?
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Tue Mar 23, 2004 12:33 am
Are you kicking the watchdog in the fetch_key() function? If not, that may cause the program to reset.
It's hard to say what the problem is. Post your full code (incluing the setjmp.h file) so we can take a look at it.
Kieran
Posted: Tue Mar 23, 2004 9:29 am
The fetch_key() function includes a delay_ms function with watchdog.
The code for the full project is long, I am trying a stripped down version (which works!). So I will try to reintroduce the bug then post it.
Kieran
Posted: Wed Mar 24, 2004 5:08 am
After further testing I have given up with the longjmp approach. It worked sometimes, no time to debug further.
