elliot
ccs error 44 |
Posted: Fri Mar 19, 2004 3:34 pm |
i just added a short function to my program and now i get this error:
error[44] C:\dig_controller\dig2_2.c 602 : Internal Error - Contact CCS PC_PR
It says the error is on line 602 but i only have 601 lines of code? Is it a problem linking? and if so why would it start now?(it worked fine before.)
thanks,
elliot |
rwyoung
Posted: Fri Mar 19, 2004 8:05 pm |
From the help file:
Quote: |
This error indicates the compiler detected an internal inconsistency. This is not an error with the source code; although, something in the source code has triggered the internal error. This problem can usually be quickly corrected by sending the source files to CCS so the problem can be re-created and corrected.
In the meantime if the error was on a particular line, look for another way to perform the same operation. The error was probably caused by the syntax of the identified statement. If the error was the last line of the code, the problem was in linking. Look at the call tree for something out of the ordinary.
Since it is reporting the error one line past your last line of code I'd take the second paragraph's advice and look at your calling tree. You may have overflowed the call stack.
Also, if you are comfortable with other people picking apart your code, you can post it here (or if very long post via a link to another web page). Please include your compiler version too. _________________ Rob Young
elliot
Posted: Sat Mar 20, 2004 12:36 pm |
Thanks for the advice. I suspect I did indeed overflow the call stack as I cannot see any problem with the linking. Here is a link to my code below if you have any idea on how i can restructure it. I'm using ccs 3.181.
Thanks,
Elliot
http://www.colostate.edu/~ebuller/
click on c code. |
elliot
rwyoung
Posted: Mon Mar 22, 2004 8:39 am |
Can you use something besides RAR. I don't feel like installing Stuffit or some other utility on my machine at work to deal with it.
How about just leaving it as your .C and .H ASCII files... _________________ Rob Young
elliot
Posted: Mon Mar 22, 2004 11:29 am |
Sorry. Yes, i'll post it as the .c and .h files. I finally got it to work and compile but the routine load_lcd_char() is using up a lot of rom as the compiler is designating it inline. If I add much else i get an out of rom error even though it says its using only 58% now. When I try to make the function #separate the characters don't get loaded right and show up as garbage.
Regards,
Elliot |
djpark
Re: ccs error 44 |
Posted: Mon Mar 22, 2004 10:00 pm |
elliot wrote: | i just added a short function to my program and now i get this error:
thanks,
elliot |
I downloaded your program which has 604 lines and tried.
I am a newbie and I might be wrong, but I get those error messages when my program is "nearly full" capacity of ROM size. My guess is that the compiler didn't recognized that it is full but tried to put in but failed. Removing some of the less essential code or optimizing helps.
I guess you are using a modified version of lcd.c? My stock version with 3.187 defines set_tris_lcd() to set_tris_d() in the lack of use_portb_lcd. On your code, it contains "#include <16F876.h>" statement, so my compiling fails unless I change it 16F877.h. Beside some custom lcd handler... |
Haplo
Posted: Mon Mar 22, 2004 11:50 pm |
Sorry dude, I tried your code but had more basic problems with it than a 'internal error' (djpark has already mentioned one of them).
Firstly, you are using PIC16F876 which doesn't have PORTD. So you have to add the line #define use_portb_lcd to your header file in order for the code to compile. This line tells the LCD driver to use PORTB instead of PORTD.
Secondly, I get an error on the lcd_shift_left() function. It isn't defined anywhere. Are you using a custom LCD driver, or is it defined in some other file? Same deal with lcd_load_char().
When I comment out all the lines containing those two functions, the program compiles perfectly. Here's the top of the .LST file:
Quote: | CCS PCM C Compiler, Version 3.187, 22700
Filename: D:\Designs\TMP\Hort_rev2_2.LST
ROM used: 5233 (64%)
Largest free fragment is 2048
RAM used: 113 (65%) at main() level
139 (79%) worst case
Stack: 8 worst case (7 in main + 1 for interrupts) |
And a few tips:
1. Your crystal is 4MHz, so use the XT fuse, not HS.
2. Interrupts are automatically disabled in the ISR so you don't need to disable them manually. This is because the PIC architecture doesn't support interrupt re-entry.
3. You are already used all of the stack, you may want to revise your code to use less stack space. If you try to use anymore stack, I'm not sure if the compiler warns about the code being out of stack space, and the code will definitely crash at some stage.
4. You haven't initialized your PORTA and PORTC directions anywhere in the code. Remember to either set the unused bits to outputs or pull them high/low. Don't let them float in input mode.
Hope this helps. |
