PCWH is generating code at 0x00 -- why?
RKnapp
PostPosted: Tue Mar 16, 2004 6:26 pm     Reply with quote
Friends,
I don't actually know if this is a problem or not, but CCS Support has not responded to my question about this topic so maybe someone here knows the answer.
My .tre file shows that main is calling a number of recognizable functions I wrote, but also a mysterious "??0??"
main  0/438  Ram=4
   ³  ÃÄ??0??
   ³  ÃÄwhystart  0/156  Ram=0
   ³  ÃÄinitialz  0/324  Ram=7
and so forth. I sometimes garner complaints, "code is outside any section", and it is sometimes shown on the stack with complaints.
The symbol table (RAM) seems innocuous:
    000 @SCRATCH
    000 x_ErrCodes
    001 @SCRATCH
    001 _RETURN_
    002 @SCRATCH
    003 @SCRATCH
    004 @SCRATCH
    005 @INTERRUPT_AREA
    006 @INTERRUPT_AREA
    007 @INTERRUPT_AREA
    008 @INTERRUPT_AREA
    009 @INTERRUPT_AREA
    00A @INTERRUPT_AREA
    00B @INTERRUPT_AREA
    00C @INTERRUPT_AREA
    00D @INTERRUPT_AREA
    00E @INTERRUPT_AREA
    00F @INTERRUPT_AREA
    010 @INTERRUPT_AREA
    011 @INTERRUPT_AREA
    012 @INTERRUPT_AREA
    013 @INTERRUPT_AREA
    014 @INTERRUPT_AREA
    015 @INTERRUPT_AREA
    016 rs232_errors
    017-0E0 x_RTflags
    0E1-0E7 x_RTtime
and so forth, so I don't observe that this "??0??" "code" is being placed in RAM. But for sure, there IS code in ROM at location 0; here is part of the .lst file:
    CCS PCH C Compiler, Version 3.187, 22420
    Filename: C:\KNAPP\NTEK_HDV100\RAK_8720\voterhdv.LST
    ROM used: 2372 (1%)
    Largest free fragment is 0
    RAM used: 344 (9%) at main() level
    355 (9%) worst case
    Stack: 4 worst case (2 in main + 2 for interrupts)
    0000: GOTO 0790
    0008: MOVWF 05
    000A: MOVFF FD8,06
    000E: MOVF FE9,W
    0010: MOVWF 07
    0012: MOVF FEA,W
    0014: MOVWF 08
    0016: MOVF FE1,W
    0018: MOVWF 09
    001A: MOVF FE2,W
    001C: MOVWF 0A
    001E: MOVF FD9,W
    0020: MOVWF 0B
    0022: MOVF FDA,W
    0024: MOVWF 0C
    0026: MOVF FF3,W
    0028: MOVWF 14
    002A: MOVF FF4,W
    002C: MOVWF 15
    002E: MOVF FE0,W
    0030: MOVWF 0D
    0032: MOVLB 0
    0034: MOVF 00,W
    0036: MOVWF 0F
    0038: MOVF 01,W
    003A: MOVWF 10
    003C: MOVF 02,W
    003E: MOVWF 11
So -- what is going on? I usually use this thing #device icd=true, so is this somehow affliated with the debugger?
I realize that there is a help item called: "Why does the .LST file look out of order?" which states:
1.  Stray code near the top of the program is sometimes under what looks like a non-executable source line.
Some of the code generated by the compiler does not correspond to any particular source line.  The compiler will put this code either near the top of the program or sometimes under a #USE that caused subroutines to be generated.
But...... at certain points, the compiler complains about this ??0?? code, so something, perhaps unimportant, seems awry. Just hearing "don't worry about it" would be an okay answer. I'm just disconcerted that whatever this is, could come back to bite. So any insight you can lend would be appreciated.
Smile Robert
ps. Another dumb question: the .tre file shows entries such as:
What are the 0 and the 324? I assume 7 bytes of RAM are consumed. Right?
PostPosted: Thu Mar 18, 2004 12:27 am     Reply with quote
Let's compare the code generated by PCM and PCH with two
absolutely minimal programs. The two compiler versions used
in this test were PCH 3.178 and PCM 3.184.
#device PIC16F877
This program creates the following .TRE file.
I have taken the liberty of changing the DOS "business graphics"
characters into dashes.
--TEST
   --MAIN  0/23  Ram=1
      --@CINIT  (Inline)  Ram=0
Now let's do it for PCH.
#device PIC18F458
That source code generates this .TRE file.
--TEST458
   --main  0/20  Ram=0
      --??0??
One likely conclusion is that the ??0?? is the "CINIT" code for PCH.
Why doesn't CCS use the proper label ? -- I don't know.
I have never seen this. What PIC are you using, and what's
your version of the compiler ?
RKnapp
PostPosted: Sat Mar 20, 2004 7:13 pm     Reply with quote
PCM,
Thanks for looking at this! I don't know whether to worry or not, but I'm generally concerned whenever CCS has a shoelace not tied.
- I'm using PIC18F8720. My compiler version is 3.187, but as you noticed, this occurs in 3.184 as well. You didn't say whether you were using ICD-U40, but I am, and was wondering if this is somehow affiliated with the problem.
Hmm ... ???
Thanks,
Smile Robert
