Mvedovetto
Posted: Thu Sep 19, 2024 9:35 am |
I want to test it. I prefer to spend some time to test before redesign and manufacture PCB board again.
Preprocessor directory #fuses NOCLKOUT, sets bit #8 of CONFIG1 register? |
Posted: Thu Sep 19, 2024 11:42 am |
Yes, but that is the default, unless your clock setup is one that enables
the clock out.
You don't show us your clock setup, so we cannot tell how things will actually
be done by the compiler.
Also if that is enabled, you would see the clock out when you run the chip
without this serial. Old thing, always check your chip is working and working
how you expect before doing complex things like Modbus.... |
Mvedovetto
Posted: Thu Sep 26, 2024 12:12 pm |
| Quote: | Yes, but that is the default, unless your clock setup is one that enables
the clock out.
be done by the compiler. |
I apologize: did not read you reply!
Here it is clock setup
#fuses NOWDT //watchdog non gestito
#fuses NOPUT //nessun mantenimento in reset dopo il POR (power on reset)
#fuses BROWNOUT //non abilita il reset quando la tensione di alimentazione scende sotto un determinato livello
#fuses NOLVP// programmazione low voltage non abilitata
#fuses NOMCLR//funzione MCLR non abilitata: MCLR weak pull-up e MCLR pin come digital I/O
#fuses NOCLKOUT
#use delay(internal=32Mhz)
Anyway do not run: seems doesn't receive in pin RX of UART1 mapped in RA4.
Once remapped UART1 in C1- C0 Modbus RTU Master runs without errors with modbus slave simulator.
Moreover, Microchip support confirms he successfully tried UART communication on PortA pin: (I hope he used RA4 for RX and RA5 for TX) and suggest to use XC8 Compiler.
I have NO time nor adequate skills to test XC8: I'll write to CCS support and in the meantime I modify PCB.
| Quote: | Old thing, always check your chip is working and working
Mistakes teach, which is why I always test the circuit board by checking the ports with the oscilloscope, pulse generator, multimeter and checking the shapes of the signals, unwanted “noise” and so on. This time I also generated a pulse signal from B7 and in turn connected it to the interface pins and matched it to the input of RC7 via software, checking with the oscilloscope channel that the signals match. |
Mvedovetto
Posted: Sun Sep 29, 2024 9:41 am |
It works! Both CCS support and Microchip support confirmed that the UART is remappable to any pin. So I asked again for support to CCS (microchip advised me to use XC8 compiler).
I used a modified ex_modbus_master.c provided by CCS support and changed the PIC16F17146 micro to be sure to start from a clean situation, then tested with ModRSim2 using also the function that adds noise to the communication and the result is that everything works fine!
By the way, before changing the micro I tested if any contact could occur, to avoid hardware errors, since it seemed not to receive info from the slave (anyway I had tested the PCB assembly before developing the application firmware): no contact nor cross connection.
If you find exceptions in the results, it is purposely caused by the simulator notifying me that it introduced noise into the communication to simulate a communication error.
5. Turn coil 6 on.
6. Write 0x4444 to register 0x03
7. Set 8 coils using 0x50 as mask
8. Set 2 registers to 0x1111, 0x2222
9. Send unknown command
Input Registers:
Data: 12 34 56 78 9A BC DE F0 00 00 00 00 00 00 00 00
Pick command to send
1. Read all coils.
2. Read all inputs.
3. Read all holding registers.
4. Read all input registers.
5. Turn coil 6 on.
Input Registers:
<-**Exception 0C**->
1. Read all coils.
2. Read all inputs.
5. Turn coil 6 on.
Input Registers:
1. Read all coils.
2. Read all inputs.
code is the same of ex_modbus_master except for specific settings:
#include <16F17146.h>
#fuses NOWDT
#define TX1_RTU_OM3_TOK PIN_A4
#define RX1_RTU_DE PIN_A5
#define TX2_MIF PIN_C0
#define RX2_MIF PIN_C1
#pin_select U1TX=TX1_RTU_OM3_TOK
#pin_select U1RX=RX1_RTU_DE
#pin_select U2TX=TX2_MIF
#pin_select U2RX=RX2_MIF
#use rs232 (UART2,stream=MMIF,baud=9600,bits=8,parity=N, stop=1,errors)
#define DEBUG_MSG(msg) fprintf(MMIF, msg)
#define DEBUG_DATA(msg,data) fprintf(MMIF, msg, data)
#define MODBUS_SERIAL_BAUD 9600
#define MODBUS_SERIAL_RX_PIN RX1_RTU_DE
#define MODBUS_SERIAL_TX_PIN TX1_RTU_OM3_TOK
#define MODBUS_PARITY "NONE"
#define MODBUS_SERIAL_STOP_BITS 1
#define MODBUS_SERIAL_TIMEOUT 300000
#define MODBUS_TIMER_USED MODBUS_TIMER_T2
#include <modbus.c>
#define MODBUS_SLAVE_ADDRESS 0x01
Upon CCS info support, the timeout was modified to consider any delays introduced by the software simulator.
So I can confirm that pins are remappable! Now I test the solution with the application software to complete test. |
