nkcruz
generate a 2.048 MHz clock, with PIC16F630. It's possible?? |
Posted: Sat Mar 20, 2004 10:02 am |
[size=18]Hello Everybody.
I can generate a 2.048 MHz clock, with the PIC 16F630. (I need square signal, Duty cycle=0.5)
has anybody experimented this?
Thanks in advance. [/size] |
Re: generate a 2.048 MHz clock, with PIC16F630. It's possibl |
Posted: Sat Mar 20, 2004 11:20 am |
nkcruz wrote: | [size=18]Hello Everybody.
In one sense, forget it.
Chose a chip with a hardware PWM module instead, and select a crystal frequency that is a nice multiple of the required frequency. One way you could do this on the 63, would be to use a 2.048MHz crystal, and run the processor on this. However the duty cycle may not then be perfect.
nkcruz
Posted: Mon Mar 22, 2004 11:38 am |
Ttelmah wrote: | nkcruz wrote: | [size=18]Hello Everybody.
Ok. I already imagined that should change my project. I believe that will implement a clock generator. Thank you for its help.
Congratulations.
Norberto |
