dmendesf
dsPIC33A support? |
Posted: Sat Aug 10, 2024 4:20 pm |
Anyone knows if dsPIC33A support is planned for future releases of CCS compiler? |
Posted: Sun Aug 11, 2024 7:42 am |
Ask CCS.
I'd say probably a while. Understand these are 32bit CPU's with a
FPU. However since the core is compatible with the PIC32, It should be
possible for CCS to support these. I wouldn't be at all surprised though
if this becomes a new 'PCE' compiler.
It is not just a small change to support these. |
empty
Posted: Sun Aug 11, 2024 10:33 am |
It may take a while if they decided to support this new family.
CCS doesn't give any support to PIC32 devices as they're MIPS or ARM architecture
based microcontrollers.
The dsPIC33A is different, it has a 32-bit CPU using Harvard
architecture, basically the same thing with other PIC/dsPIC devices.
I hope we'll see a full support of these devices. |
Posted: Sun Aug 11, 2024 11:28 am |
Agreed. It is actually even more compatible than that, the instruction core
matches the 16bit units. However a lot of the peripherals are different, which
is why I suspect they may launch it as an alternative, rather than just an
extension to PCD. Crossing things that they do decide to support these
on a new version of the existing compiler.
However given how radical the changes are, I'd be very careful for a few
versions if they do do this.....
Asking them is the thing to do. |
