jeremiah
Posted: Wed Aug 07, 2024 1:25 pm |
Yep yep, that's fine, I wasn't really addressing that part as it was already covered in previous discussion. I was just letting the OP know that the statement I highlighted earlier was not fully correct for that family they were using. |
reelthymes
Posted: Thu Aug 08, 2024 6:56 am |
Ttelmah wrote: | You are right on this chip. On most chips they are not relocatable.
However using the interrupts, you will have problems with bounce.
Understand they a simple keyboard may well give a dozen or more
makes when a key is pushd. It depends massively. on the quality of
the contacts, and how the user pushes the key |
So is bounce not an issue when using an "input change notification" (CN) pin? As for debounce in general, can't that simply be handled in the software, i.e. you sample the input at some interval and consider the signal stable if it's consistent across intervals?
Would this software debounce method work for either pin type (external interrupt or CN input)? |
gaugeguy
Posted: Thu Aug 08, 2024 11:25 am |
To debounce a switch input you would not use an external interrupt or a change interrupt at all. Just poll the pin input at a regular interval and look for a stable change of state.
An interrupt on a switch would only be useful if you need to wake from sleep on a switch press. |
reelthymes
Posted: Thu Aug 08, 2024 12:58 pm |
gaugeguy wrote: | To debounce a switch input you would not use an external interrupt or a change interrupt at all. Just poll the pin input at a regular interval and look for a stable change of state.
Ok, thanks this is is helpful. So in this case, if I were to simply poll the pin input at regular intervals, doesn't this risk being unresponsive or slow because now it's part of my main program loop? i.e. the polling action may have to wait for many other actions to complete before being reached... whereas a change notification interrupt would be immediate?
I also thought that was the general point and application of interrupts. i.e. they exist to make your program respond immediately to some event (usually some external stimulus).
Or I suppose as Ttlemah previously stated, I could use a timer interrupt? |
gaugeguy
Posted: Thu Aug 08, 2024 1:25 pm |
Not in a properly written program.
10ms is a long time from a microprocessors view.
200ms is a short time from a human response view. |
jeremiah
Posted: Thu Aug 08, 2024 1:43 pm |
reelthymes wrote: |
That's also an option. I have a few programs where I have a spare interrupt running that takes a 16 bit variable, shifts it left one bit and OR's in the input of the pin in question. Then in my main code , I look to see if the pin is debounced high (variable = 0xFFFF), debounced low (variable = 0x0000, or in transition (an other value).
Something like (untested, just typed out freehand)
#define PIN_LOW 0x0000
#define PIN_HIGH 0xFFFF
volatile unsigned int16 g_PIN_B6_debounce = PIN_LOW;
#INT_TIMER5
void debounce_timer(){
g_PIN_B6_debounce = (g_PIN_B6_debounce << 1) | input_state(PIN_B6);
void main(void){
static unsigned int16 last_PIN_B6 = PIN_LOW; // assuming initial state
// setup timer 5 to some reasonable debounce time
while(TRUE){
if(last_PIN_B6 == PIN_LOW && g_PIN_B6_debounce == PIN_HIGH){
last_PIN_B6 = PIN_HIGH;
//rising edge processing
if(last_PIN_B6 == PIN_HIGH && g_PIN_B6_debounce == PIN_LOW){
//falling edge processing
// ignore other values of B6 until it debounces to a known value
reelthymes
Posted: Thu Aug 08, 2024 1:58 pm |
jeremiah wrote: | reelthymes wrote: |
#INT_TIMER5
void main(void){
while(TRUE){
That looks like a great solution, thanks for sharing. |
jeremiah
Posted: Thu Aug 08, 2024 2:03 pm |
reelthymes wrote: |
No problem. If you find the interrupt takes too much time you can simplify the generated code at the cost of a less readable solution:
#INT_TIMER5
#BIT B6_BIT = g_PIN_B6_debounce.0;
g_PIN_B6_debounce = g_PIN_B6_debounce << 1;
B6_BIT = input_state(PIN_B6);
That reduces the generated ASM quite a bit. That takes the generated code down to:
.................... #BIT B6_BIT = g_PIN_B6_debounce.0;
.................... g_PIN_B6_debounce = g_PIN_B6_debounce << 1;
020E: SL 800
.................... B6_BIT = input_state(PIN_B6);
0210: BCLR.B 800.0
0212: BTSC.B 2CA.6
0214: BSET.B 800.0
You can also change the 16 bit global to an 8 bit global (and the constants) if you think you only need 8 debounce attempts |
reelthymes
Posted: Fri Aug 09, 2024 9:26 am |
Quote: |
void main(void){
regarding setting up the timer period, please see my below reasoning. Can you let me know if I'm in the ballpark or is this totally off-base?
I have the following line in the setup portion of my main() function: Code: | setup_timer_1(TMR_INTERNAL, 0x0148)); |
Here is the logic behind this:
1) The PIC24 has an 8 MHz internal clock. That means the period of each clock cycle is 0.125 us.
2) The 16 bit timer has max value of 0xFFFF (65,535), which means that 8*10^6 / 65535 = 122. This is the number of cycle count per bit of the timer.
3) Therefor, each bit of the timer represents (122 * 0.125 us) = about 15 us
4) so, for a (I think reasonable?) period of 5 ms for my interrupt, I should set the period value of ( 5ms / 15 us = 328). In other words, 328 (0x148).
5) so, the interrupt will fire every 5 ms, and we keep going until the g_PIN_doubounce variable is filled up with all 1s (0xFFFF). So this will occur at approx. 75 ms because (5 ms * 16 = 75 ms). i.e. if I understand your algorithm correctly, inside the interrupt we OR the pin HIGH input with that variable and keep shifting left until the whole thing is filled up. So that means 16 passes through the interrupt routine to ensure a stable signal.
Lastly, is there a reason you recommended timer 5 as opposed to one of the others? |
jeremiah
Posted: Fri Aug 09, 2024 5:57 pm |
reelthymes wrote: |
I wasn't intending to suggest timer 5 specifically. It was more just for example. On most (all???) PIC24FJ chips, timer 1 is the only timer with an asynchronous input, so we reserve that one for our external 32KHz crystal in order to wake our boards up from full sleep using a timer (other timers normally cannot do this). I just picked a timer at random for the example.
In terms of your timing, I would always recommend you toggle an I/O line using the timer interrupt and measure it on a scope to verify the timing and your clock settings. PIC24's divide the incoming clock by 2x so the 8 MHz would be 4 MHz (unless your clock is really 16 MHz, then it would be 8MHz). (SIDE NOTE: PIC18s and below divide the clock by 4x).
You are correct about my algorithm that it takes 16 passes (due to the unsigned int16 type). And my algorithm does wait until all 16 are 1's but also makes sure the last time it was full it was all 0's before (essentially a rising edge). That way the stuff in the IF only triggers once until the logic goes low 16 times and then high 16 times again (so a falling edge followed by a rising edge). Hopefully that makes sense. |
Joined: 01 Jul 2010 Posts: 9445 Location: Greensville,Ontario
Posted: Fri Aug 09, 2024 6:59 pm |
One potential issue with software debounce is that you've got it working perfect with brand x, style 3 switches then.... have to buy brand k, style 1 switches, which of course have a totally different debounce 'action'.
You can lose a lot of time over this head scratcher....really, all switches are the same , right ????
I learned decades ago to spend a few pennies in hardware to get solid,clean signals. Usually 'hard' pullups, 1mfd filter caps, schmitt(sp) buffers. In automotive products ,used 5V regulators as +12 to +5 level converters. Boss said that adds cost but SAVED money as NO defective boards due to 'front end' damage. |
Posted: Sat Aug 10, 2024 1:44 pm |
and (of course), switches that are fine when you build the unit, then
give bounce problems in the future, or when a different person uses the
key....  |
reelthymes
Posted: Mon Jan 27, 2025 7:54 am |
I have a PIC24 device and I use MPLAB 8.x and the CCS compiler. I am posting in the original thread I created and here is a summary again of my use case:
I want to simply read the state of one of the GPIO pins on my board, then take some action, depending on the logic state at that pin. The state of the pin corresponds to the state of a mechanical switch (SPDT) in the physical world.
Previously on this thread, someone had suggested doing the following (use a timer interrupt) to accomplish my goal while also accomplishing debounce:
Code: | PIN_LOW = 0x0000;
PIN_HIGH = 0xFFFF;
volatile unsigned int16 g_PIN_D0_debounce = PIN_HIGH; |
inside a timer interrupt:
Code: | g_PIN_D0_debounce = (g_PIN_D0_debounce << 1) | input_state(PIN_D0);
So once the input state of the pin has stabilized, the main routine will check this state vs the previous state and take its action.
if(last_PIN_D0 == PIN_LOW && g_PIN_D0_debounce == PIN_HIGH)
last_PIN_D0 = PIN_HIGH;
//close switch port A
if(last_PIN_D0 == PIN_HIGH && g_PIN_D0_debounce == PIN_LOW)
last_PIN_D0 = PIN_LOW;
//close switch port B
But I've realized that the issue is that the switch I am working with is not a "latch" type switch. i.e. pressing the switch button only connects the secondary terminal momentarily. Otherwise, the primary terminal is always connected. So the algorithm would need to change to something like this:
Code: | Bool terminal1_connected; //(need to find the initial state of the switch, i.e. what terminal is it connected to? That way when a switch is made, we know what to do)
if(g_PIN_D0_debounce == PIN_LOW)
if(terminal1_connected)
terminal1_connected= false;
terminal1_connected= true;
This approach could work, but the question is, is the time that the mechanical switch depressed greater than the time it takes the multiple calls to the timer interrupt to fill up its buffer variable?
When I set up the timer interrupt I set it for (I believe) 5 ms.
// Setup the timer interrupt
Code: | setup_timer1(TMR_INTERNAL, 0x014A); // setting period to roughly 5ms
I have done some research and there are claims that a typical pressed button will be connected for several hundred milliseconds. That should be more than enough for this scheme to work.
Keep in mind that there is an equivalent button switch design from the manufacturer that is a "latch" style, and would therefore make all this unnecessary and I could go with the original approach.
But I would think there is some logical way to resolve this with the switch being the way it is now.
Any thoughts? |
Posted: Mon Jan 27, 2025 8:18 am |
well 1st thought...
this.. there are claims that a typical pressed button will be connected for several hundred milliseconds.
Is 99.44% a LIE ! Unless of course the person pressing the button keeps pressing it !!!
All mechanical pushbuttons do have 'contact bounce' ,so you can get a few to several 'button pressed' signals. Lots of ways to get ONE result from the action.
Based on 'active high'connection( pullup on PB )
hardware options
1) low value pullup resistor
2) capacitor in parallel with PB
3) feed PB into a Schmitt based interface schip
software options
1) ISR based code
2) timed polled code
3) inline delays
4) counts
In the 'code library' here you'll find someone converted the BUTTON() function from another source into CCS C. It works and it has several 'options', like active high, active low,timings. It's well worth exploring.
Someone could ( maybe has ) write a BOOK on the subject of how to get perfect push button responses !
This is based on SPST pushbuttons, it'd be interesting to see HOW you've connected the SPDT PB. Really 'overkill' unless you're doing security/alarm systems though. |
reelthymes
Posted: Mon Jan 27, 2025 9:02 am |
[quote=
[/quote]
Can you tell me where I can locate the code library? I searched for it but couldn't find it. |
